Thread: Mafia Sound Issues
November 24th, 2002, 04:22 PM #1
Mafia Sound Issues
Greetings- Wasnt sure whether to put this in MutliMedia/Audio or here... or heck- even in a different GamingForum, but settled on this one
AnyWays- I am having some frustrating sound issues with Mafia. To start with- I have searched Mafia's Forum with keywords and tried all suggestions there... but cant find a GOOD solution. So, I hoped some gamers here may have an idea.
Its like this- I have onboard sound- AC97 on an MSI 648 Max (L series). Since installing this Mobo, I have been unable to play the game because if I try and Run Quadraphonic Sound- I hear sound effects, but no voices in gameplay or cutscenes. Here is what I have done...
-Cntrl-alt-delete'd out of game after start and changed speaker config back to quadraphonic (the game intro is in stereo and forces the speaker setting back to stereo)
-Disable/Enable EAX to no avail
-All sounds do work in Software Mode- but gameplay is then choppy
I have all the latest drivers installed for Mobo, Sound and Video
Strangely, Even if I try to play the Game in stereo- desktop set at Stereo and Game set at Stereo, I still dont get voices. There is no official support at Mafia, only forums. I have exhausted that option.
At this point, I am happy to just get Stereo back and working... but cant even get that. ANY and ALL Help is appreciated. I was halfway through this game when I upgraded my system and started having probs.... I think it is/was Great- now I want to finish it
Thanks for the Support and Ideas,
Mortis
November 27th, 2002, 09:53 AM #2
I don't have the game.. but here is a bump.. and a few questions..
What did you upgrade that changed your systems specs? have you tried uninstalling the game.. reinstalling it.. trying it without patches installed.. and/or trying a patch that you know was working for the game?
also might try dxdiag. by going to Start>Run and type in dxdiag.. and turn down hardware sound.. and check through options for the sound to see if anythign can be adjusted to help..
last solution.. buy a sound card and get off that on board pos.. u can get a sound blaster 16 cheap.. like 20 bucks.. if u want somethign more.. get a turtle beach sqanta cruz card.. its better then a sb live, or audigy card.. and its onyl about 60 bucks.. can't get either.. ask a friend for a old sound card.. do something to get off on board sound.. to many problems..In life one must Chill
November 27th, 2002, 11:50 AM #3
Thanks Daft... I have tried all the things you suggested except for the NewSoundCard, hehe. I dont think I need a new sound card, the RealTek Sound I have onboard sounds good and I cant fully utilize it- between it and my 6 channel sound, I cant turn it up now or the neighbors bang on my door (Apartment Complex
Yea, I did a clean install after upgrading the Mobo including OS and all software... I have twice reinstalled the game thinking the SetUp files determined my 6 channel sound and continued to try and use it so I reinstalled with Stereo Sound enabled hoping to fix it and also installed in another configuration. I have messed with DxDiag, etc.
This is the First Time I have experienced SoundIssues in a Game... after reading the Forums at Mafia, Many seem to be having issues. I cant justify to myself purchasing a Card for one game... so maybe I will put this one on the shelf (which I dont want to do) and see if I have similar issues in the future, if I do, I will consider getting a new SoundCard at that time.
Thanks for Your Ideas and ^Bump^.
Mortis
November 27th, 2002, 05:41 PM #4
np.. to bad u don't have it working.. I know you said u don't need a different sound card.. but I can tell you on board sound is the pits.. there are some nice ones out there.. but nothing like a true sound card.. its like on board video.. u know that is junk.. same goes with sound.. =)
I'd say don't look at it as buying a sound card for one game.. as games go along.. they are getting more advanced and need a quality sound card..
the sound problems do wound like a driver issue though.. do you have sound controls other then windows?
also check what irq the onboard sound is using.. it could be it is using a irq that the games voice audio can't see.. if u remember back in dos days u could have games that music would work but voices didn't b/c of irq..
humm u might think about posting this in general tech.. even though this is a game sound problem.. it could be a system irq problem.. that maybe someone in general tech who doesn't come to this forum.. could answer..In life one must Chill
November 27th, 2002, 11:56 PM #5
Blasted! Dang... Your analogy about onboard sound compared to onboard video has me wondering about the other side
. That TurtleBeach at NewEgg looks good! lol.
Thanks... I will let this hang around for a while before I buy. I will look into the IRQ thing, good suggestion.
Mortis
EDIT: Yes, I have "Sound Effect" options that installed with the drivers... I have played with those also, even disabled from startup and then reinstalled the game.
November 28th, 2002, 03:36 AM #6I have the santa cruz if thats what you're talking about. Anyway, unless I turn sound acceleration to basic in dxdiag, the game runs and sounds really bad.Originally posted by Mortis
November 28th, 2002, 01:24 PM #7
Got it working
. I had turned the hardware acceleration down in DxDiag, but did not disable it. I disabled it and all works well now.
Thanks for the ideas and assistance! Time to blow things up
Mortis
November 28th, 2002, 07:01 PM #8
great to hear.. the dxdiag has become a handy tool to get allot of games working for ppl.. I've used it a few time on sound issues to get a game working.. glad u r rocking.. be sure to do a few drive by for me.. =)
I'm using a 4GB SD card for RB in my laptop and it has noticeably decreased boot time and program startup time. It took about five or six days to learn the routines though.
