Thread: americas army problem...
May 5th, 2003, 06:04 PM #1
i was previously running version 1.6 with no problems. i downloaded 1.7 last night, the full game, not the patch. i uninstalled v1.6 and then proceded to install v1.7. the winxip unzipper comes up and takes forever to unzip all the files and when it gets done, a message comes up asking me to install aim expressions!? i figure, well they must have included it with the install, so i hit "no". nothing. americas army is not installed and the files that were unzipped are gone. so i try again, this time i say "yes, install your dumb aim crap". aim expressions installs fine. AA is still gone. nothing. i think "must be a problem with the setup file". so i uninstall aim expressions. then i decide to reinstall v1.6, which has previously worked fine. it takes forever unzipping, then when it gets done, "wanna install stupid aim expressions?" i scream. i hit no. nothing. AA is not installed or to be found anywhere. i searched my whole c:\ partition and d:\ partition. i try again and hit yes. nothing. no AA. note that the v1.6 file is known to have worked before. wtf is going on!!?? please help me!
drewVisit http://duroo.org
May 5th, 2003, 06:09 PM #2
clear your temp directory and reunzip..
May 5th, 2003, 06:10 PM #3
as in the c:\windows\temp directory?
i will try but i think it is empty already.
thanks
drew
EDIT: yup. completely empty. no luck
May 5th, 2003, 09:14 PM #4
fixed it. instead of using the self extractor that the file comes as, i opened it in winrar and then extracted it. i should have thought of that earlier. but thanks for the help thronka!
Hi This is a really nice screenshot programmer. I like most in programme is screen shots of Green shots in action, its looks nice.
Really nice screenshot program
