Go Back   Tech Support Forums - TechIMO.com > Single and Multiplayer Gaming > General Gaming Discussion
halo 4 xbox help not working
Currently Active Users: 1171
Discussions: 200,929, Posts: 2,379,148, Members: 246,296
Old January 1st, 2004, 08:36 PM   Digg it!   #1 (permalink)
Send a message via AIM to squik-man Send a message via MSN to squik-man
Unhappy
hey do any on you have x box??
for those who do do u have halo for it? cause i do and for some reason my halo just wont work for my x box
can someone plz tell me y its not working????
squik-man is offline   Reply With Quote
Old January 2nd, 2004, 11:04 AM     #2 (permalink)
Xtreeme's Avatar
Explain wont work. I.E. wont boot with that cd? Wont play proper. Wont leave main menue? What? Could be bad disc. You just get it? If so try returning to store for another.
R.I.P. TKOP
Xtreeme is offline   Reply With Quote
Old January 2nd, 2004, 11:10 AM     #3 (permalink)
Cyclone2's Avatar
I had that once but cleaned the cd and all was well
Cyclone2 is offline   Reply With Quote
Old January 2nd, 2004, 06:53 PM     #4 (permalink)
yea i cleaned it but it still wont work any way it will go to a loading screen before the menu and it will load half wal then stop and go backwards.
i brought it to best buy and they let me put it in there xbox and it worked perfectly.
but the guy said that there might be a problem with the memory so i went home and cleaned the whole xbox out. i deleted all the memory for halo and it still didnt work.
Y???????????
its only cool till i ad the "k" <-----.
Old January 3rd, 2004, 02:19 AM     #5 (permalink)
carpe noctum
Warthog's Avatar
Send a message via MSN to Warthog
I went through 3 copies of Serious Sam for XBox before returning it completely to the store I got if from and going to another store.
Fourth copy worked fine.
Warthog is offline   Reply With Quote
Old January 3rd, 2004, 02:23 AM     #6 (permalink)
No pants, Wearin'a Helmet
MitaDC's Avatar
Send a message via ICQ to MitaDC Send a message via MSN to MitaDC Send a message via Yahoo to MitaDC
When a cd doesn't work for me then I just rip apart my xbox and clean off the lens and put it back together...have u tried that??
Dr. Cox -Newbie, Stay. Oohhh what a good boy you are, Newbie..... DEAR GOD JUDY HOW MUCH PRODUCT DO YOU USE?
J.D -None. It's like this when I wake up
MitaDC is offline   Reply With Quote
Old January 3rd, 2004, 02:35 AM     #7 (permalink)
Xtreeme's Avatar
Try a DVD dry brush cleaning disc. $10 at wall-mart, staples etc. and since xbox has a dvd-rom it will be perfect for it. That way you wont have to void xbox warrenty taking it apart.
Old January 3rd, 2004, 01:20 PM     #8 (permalink)
yea i tryd that cleanning and takeing xbox apart but it still wont work.
"now my dad is really pissed" that was his favorite game now hes stuck playing xiii
Old January 4th, 2004, 11:49 AM     #9 (permalink)
Xtreeme's Avatar
So it did work before but not now?
Old January 4th, 2004, 01:45 PM     #10 (permalink)
yes exactly
Is It Just Me? (2868)
Obama the Muslim (14)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
