Results 1 to 4 of 4
    Jan 2004
    Norman, OK
    35
    Building a Game Machine... Need Advice
    First, I need to decide what kind of motherboard to run. I am thinking about the following:
    Gigabyte GA-8IPE1000
    Intel 865PE Model BOXD865PERL
    Asustek P4C800 Deluxe
    The Asus is quite more expensive than the other two, and initially I had a better impression on the Gigabyte, but I would like you guys out there to post your opinion on which would be the best buy. Also, if you have another board in mind, don't hesitate to let me know!
    I already have the following:
    Pentium 4 2.4 GHz
    3DProphet Hercules Radeon 9800 Pro 128 MB
    2 GB DDR SDRAM (2 DIMMs)
    80 GB 7200 RPM Hard Drive
    CD-RW/DVD Combo Drive
    Floppy
    500 Watt Power Supply
    I'm thinking of buying a new case; I saw the case posted by washe, a RainMax Silver Mid-Tower for under $50.
    Essentially, I would like to know if it would be wise to go for a faster processor and which motherboard I should buy. Thanks for the help!
    Ultimate Member Friedchicken100's Avatar
    Nov 2003
    Richmond, VA
    2,528
    I've always gone with Intel. They are very reliable. Also, their processors are easy and fairly to upgrade.
    My other car is a T-34.
    Ultimate Member pinipig523's Avatar
    Aug 2003
    ChiTown, IL
    1,320
    i built my friend an intel based pc.... 2.8c. i overclocked that mother to 3.4ghz stable (based on prime95 tests) and coupled with 1gb of dual channel ddr500 ram. the fsb was running at 242x4 ~968mhz.
    was i impressed?
    NO.
    i run an amd 3500+ with 1gb dual channel ddr400 and i am far more impressed by my setup than his. not to mention, mine was half the price of his setup.
    Father V2.0 washe's Avatar
    Feb 2002
    Mexicali, Mexico
    5,142
    mmmm, the items I choose are becoming popular these days....
    About Intel boards I'm dont have much knowledge last one I bought was an ASUS P3V4X, altought that one is for P3, very good and stable motherboard.. I was an Intel guy before, but best bang for the buck are AMD....
    Maybe you can look for a case without a power supply, you are already buying one.....
    someone is more skilled than you!
    http://s7.bitefight.org/c.php?uid=23753
