Help with these Diagnostic type messages
Currently Active Users: 1860
Discussions: 200,923, Posts: 2,379,092, Members: 246,290
Old February 15th, 2004, 02:50 PM   Digg it!   #1 (permalink)
Unhappy
Howdy All,
As of yesterday afternoon I seem to be getting these wierd diagonstics that pop up everytime someone logs into their profile. I have no idea what they are, or how to get rid of them. The only thing out of the ordinary I did was install a free upgrade on Sonic MyDVD V4 to V5 yesterday, but I have uninstalled it and these still seem to be popping up whenever I log on. If I close one, they all disappear and everything works fine, but I'm wondering what the heck they are?? Any of you smarty pants have any idea what these might be??
I'm running Windows XP home for an O/S. The program icons that seem to be associated with the DOS looking windows are half black/half white box with a green cross in the middle. I'll paste in the messages associated with the windows I'm getting below:
Thanks for the help,
Max
1) Dispatch\Tfsnifs window gives this message:
IRP_MJ_FILE_SYSTEM_CONTROL 1 STATUS=c000014f (FScode=0)
2) Dispatch\\??\TFSWIFS
Shows nothing in the window
3) Diagnostic Traces window gives this message:
SSDIAG activated
new _DIAGWINDOW(DrvnQ117)
delete _DIAGWINDOW(DrvnQ117)
new _DIAGWINDOW(DrvmCDB)
new _DIAGWINDOW(DrvnCDB)
delete _DIAGWINDOW(DrvnCDB)
new _DIAGWINDOW(DrvnPPqT)
delete _DIAGWINDOW(DrvnPPqT)
new _DIAGWINDOW(DrvmCDB pending IO)
delete _DIAGWINDOW(DrvmCDB pending IO)
new _DIAGWINDOW(Dispatch \??\TFSWIFS)
new _DIAGWINDOW(Dispatch \Tfsnifs)
AllocateBuffer 821E8000
AllocateBuffer 82218000
AllocateBuffer 821D8000
AllocateBuffer 821C8000
AllocateBuffer 821B8000
AllocateBuffer 821A8000
AllocateBuffer 82198000
AllocateBuffer 82188000
4) DrvmCDB window gives this message:
Install-SUCCESS
API Ver/Min: 000f/0002
Yield: 00000000
Rates: 0000h
Max Rate: 0000h
Max Buf: 8000h
Cmds Avail: 00000000h
Task Mode: Async
Server:
| Adapter: Search | Make: ?(0) | [ ] Burst |
| Addr: 0 | Model: | [ ] Safe |
| Port: - | Size: 0 | [ ] NoReset |
| IRQ: - | Speed: - | [ ] Slow IO |
| DMA: - | Rom: 0000h | [ ] NoComprs|
| Intfc: Search | Class: - | [ ] Tested |
| Remote: | Periph:- | [ ] HsSearch|
|_________________________________________________ __________________|
CONFIGFIRST 0000 -------- ---- ---- --- -------- ---- 01-00-00-00-0000 -SUCCESS
| Adapter: atapi | Make: HL-DT-ST | [ ] Burst |
| Addr: 0.0 | Model: CD-ROM GCR-8481B | [ ] Safe |
| Port: 0h | Size: 0 | [ ] NoReset |
| DMA: - | Rom: 1.06 | [ ] NoComprs|
| Intfc: SCSI PORT | Class: DASD | [ ] Tested |
| Remote: | Periph:CDROM | [ ] HsSearch|
-0 0ms
DRIVEPATH 0000 0 ---- 4 --- -------- ---- 1b-00-00-00-0000:44 3A 5C 00 B8 9A 04 FA D:\..... -SUCCESS-0 0ms
CONFIGNEXT 0000 -------- ---- ---- --- -------- ---- 02-00-00-00-0000 -SUCCESS
| Adapter: atapi | Make: SONY | [ ] Burst |
| Addr: 1.0 | Model: DVD RW DRU-510A | [ ] Safe |
| DMA: - | Rom: 1.0d | [ ] NoComprs|
-0 0ms
DRIVEPATH 0000 0 ---- 4 --- -------- ---- 1b-00-00-00-0000:45 3A 5C 00 B8 9A 04 FA E:\..... -SUCCESS-0 15ms
CONFIGNEXT 0000 -------- ---- ---- --- -------- ---- 02-15-1c-02-0000 -NO_DRIVE-0 0ms
Uninstall
Install-SUCCESS
Yield: 00000000
Rates: 7000h
Max Rate: 4000h
Max Buf: 8000h
Cmds Avail: fcf253feh
Task Mode: Async
Server:
OPENDRIVE 0000 -------- ---- ---- --- -------- ---- 03-00-00-00-0000 -SUCCESS-0 0ms
SetMode:Async
CHECKDRIVE 0000 -------- ---- ---- --- -------- ---- 1f-00-00-00-0000 -SUCCESS
------VALID------
[ ] battery
[x] writable
[ ] bg formatting
[ ] hiddendefects
[ ] needs leadout
-0 0ms
CHECKMEDIA 0000 -------- ---- ---- --- -------- ---- 1a-14-23-00-3a00 -NO_MEDIA-0 0ms
CLOSEDRIVE 0000 -------- ---- ---- --- -------- ---- 04-00-00-00-0000 -SUCCESS-0 0ms
Uninstall
Install-SUCCESS
Yield: 00000000
Rates: 7000h
Max Rate: 4000h
Max Buf: 8000h
Task Mode: Async
Server:
OPENDRIVE 0000 -------- ---- ---- --- -------- ---- 03-00-00-00-0000 -SUCCESS-0 16ms
SetMode:Async
------VALID------
[ ] battery
[ ] writable
[ ] bg formatting
[ ] hiddendefects
[ ] needs leadout
-0 0ms
Uninstall
maximus01can is offline   Reply With Quote
Old February 15th, 2004, 03:23 PM     #2 (permalink)
AzKidd69's Avatar
Send a message via MSN to AzKidd69 Send a message via Yahoo to AzKidd69
check in msconfig and see if there are any new things added.. I have this gut feeling ( and no reason for it) that the windows stem from there
Never argue with a computer, without a hammer.
Never program and drink beer at the same time.
Never trust a programmer who carries a screwdriver.
AzKidd69 is offline   Reply With Quote
Old February 15th, 2004, 09:13 PM     #3 (permalink)
Problem is I'm not exactly sure as to what would be new and what was there to begin with in msconfig. I have been there a few times and limited the startup programs, but Maybe I can check the startup tab and see if there's something new.
Thanks,
Max
Old February 15th, 2004, 09:20 PM     #4 (permalink)
AzKidd69,
I checked in msconfig and found a program called ssdiag.exe that was running on startup. I stopped it from booting on startup, but not sure whether I should delete the program or not. It does not start now after disabling it. Maybe it's no problem, just don't know where it came from. Thanks for the tip.
Max
Old February 16th, 2004, 11:53 AM     #5 (permalink)
AzKidd69's Avatar
probably from that upgrade you did and it just did not clean up like it should have when you un-installed the upgrade. It was probably supposed to be a one time run diagtool that for some reason did not remove itself like it should have.
Old March 24th, 2004, 12:15 AM     #6 (permalink)
Does anyone really understand this man's problem?
I have the exact same thing happening on my pc and I want to know why and how to properly address it.
I don't want to delete anything until I know what caused it!
Thanks very much
RickySea
RickySea is offline   Reply With Quote
Old March 24th, 2004, 12:31 PM     #7 (permalink)
RickySea,
If you look above to my last response. I found in msconfig a proggie called ssdiag.exe so I just stopped it from starting and if I remember correctly, removed it in add/removes programs and the problem was gone.
Max
Is It Just Me? (2854)
Obama the Muslim (13)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
