Results 1 to 9 of 9
    Fur ballin Sixpac_XP's Avatar
    Victoria, BC
    4,371
    Toshiba Satellite laptop help!
    I have a Toshiba Sattelite laptop and loaded Windows XP on it.. but the only thing is I want to install the extra drivers and utilities provided from Toshiba. I do not have the CD or manuals that came with it and I have no clue what model this sucker is.. it doesn't say it on the laptop at all! I can't believe it!!!
    so arugh.. now I don't know what to download.
    Is there a way I can find out what model of laptop I am working with? I tried looking in the bios but it doesn't say anything.. nor during startup either.
    Where's the beef? Scott Tiger's Avatar
    Mar 2002
    Southwest, VA
    3,586
    This might help
    Where's Lunch?
    Senior Member imac9556's Avatar
    Oct 2002
    Leawood, KS
    828
    Hi there!
    Go to:
    http://ts.toshiba.com
    and select your toshiba laptop modem to download the drivers/utilities.
    To find your model number of your computer, look on the bottom of your laptop and there should be a toshiba label with the model on it.
    If not,
    try downloading SiSoft Sandra and look under the system info. It should list the model number / manufacturer.
    http://www.sisoftware.co.uk/
    I hope this helps, Paul
    Victoria, BC
    4,371
    Dang, neither program told me what the model number of the computer is .... just info like motherboard and video etc... and there is no sticker on the bottom of the computer..just the serial number and Windows License info.
    --- Standby to receive our transmission ---
    Oct 2002
    Leawood, KS
    828
    Um... Call toshiba. (go to the link that I provided above)
    When you call toshiba, you give them your serial number for your laptop. They they should be able to identify what lappy you have
    Victoria, BC
    4,371
    Just wondering if anyone can figure it out from the info I got from SiSoftware Sandra:
    SiSoftware Sandra
    System
    Host Name : VICPDUNIONLAPTO
    User : union
    Domain : VICPDUNIONLAPTO
    Processor
    Model : Intel(R) Pentium(R) III Mobile CPU 1000MHz
    Speed : 997MHz
    Performance Rating : PR1196 (estimated)
    Type : Mobile
    L2 On-board Cache : 512kB ECC Synchronous ATC (8-way, 32 byte line size)
    Mainboard
    Bus(es) : ISA AGP PCI CardBus USB FireWire/1394 i2c/SMBus
    MP Support : No
    MP APIC : No
    System BIOS : AT/AT COMPATIBLE
    Total Memory : 127MB SDRAM
    Chipset 1
    Model : Toshiba America Information Systems 82830MP SDRAM Controller / Host-hub Interface (A4-step)
    Front Side Bus Speed : 1x 133MHz (133MHz data rate)
    Total Memory : 128MB SDRAM
    Memory Bus Speed : 1x 133MHz (133MHz data rate)
    Video System
    Monitor/Panel : Default Monitor
    Monitor/Panel : Plug and Play Monitor
    Adapter : NVIDIA GeForce2 Go (Microsoft Corporation)
    Physical Storage Devices
    Hard Disk : TOSHIBA MK2017GAP
    CD-ROM/DVD : TOSHIBA DVD-ROM SD-R2002
    Logical Storage Devices
    Hard Disk (C : 18.6GB (16.0GB, 86% Free) (NTFS)
    CD-ROM/DVD (D : N/A
    Peripherals
    Serial/Parallel Port(s) : 1 COM / 1 LPT
    USB Controller/Hub : Intel(R) 82801CA/CAM USB Universal Host Controller - 2482
    USB Controller/Hub : Intel(R) 82801CA/CAM USB Universal Host Controller - 2484
    USB Controller/Hub : Intel(R) 82801CA/CAM USB Universal Host Controller - 2487
    USB Controller/Hub : USB Root Hub
    FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller
    PCMCIA/CardBus Controller : Texas Instruments PCI-1420 CardBus Controller
    Infrared Device : SMC IrCC - Fast Infrared Port
    Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
    Mouse : PS/2 Compatible Mouse
    Mouse : Microsoft USB IntelliMouse with IntelliEye
    Human Interface : Microsoft USB IntelliMouse with IntelliEye
    MultiMedia Device(s)
    Device : Intel(r) 82801CA/CAM AC'97 Audio Controller
    Communication Device(s)
    Device : TOSHIBA Software Modem AMR
    Power Management
    AC Line Status : On-Line
    Battery No 1 : 100%
    Operating System(s)
    Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 1)
    Network Services
    Adapter : Realtek RTL8139 Family PCI Fast Ethernet NIC
    Retired mostly.
    Finland
    5,150
    I think it's model 2805-S???
    http://www.google.fi/search?q=geforc...oe=UTF-8&hl=en
    The only http result from that is the 2805-S402 (which has a bit slower cpu clock, but otherwise seems similar)
    Browsing the toshiba downloads, shows pretty much all 2805-S??? models have geforce2 go, so I would shoot for that
    Where has your model# sticker gone?
    Mar 2004
    13
    Did you check the system information? I also have a Toshiba Satellite running on XP. I just looked this up for mines and it showed the model (Satellite 1800).
    Aug 2005
    Ocala
    How do u find out ur model number
    can u find ur model number on ur comp. i have these buttons below my power button they are play/pause stop etc. but they aint working how do i get them to start working please email me because i dont get on this site to much.My email address is on my profile but jus in case it aint on there its babyboy_4455@yahoo.com or Travis862@hotmail.com
