If it is similar to the "remote switch" as used with ATX type PSUs in computers, it means that the actual heavy current power switching takes place inside the Power Supply (usually by an electronic switch or a latching relay) rather than by the physical switch (the one you actually press or flip) itself. Therefore you can use a lighter duty switch and much lighter wire to the physical switch than would be needed if it actually switched all the current.
. Or, it could just mean something else entirely as mentioned by the others.
.bh.
