I know logitech Keyboards come with the adaptor, so if oyur up to getting one of those you can always look into USB Hubs. Try going to Newegg.com and in the search type in "USB Hub". as far as i know Belkin is a good brand to use
On another note, you can always pick up and install a USB card and get a USB 2.0 connection (They are drastically faster than 1.1). so long as you have a free expansion slot and they can be found for under $20
See the lights Blinking on your Modem? Thats me Hacking you! - adapted from an IRC log.
