Help with 98 install
Currently Active Users: 1605
Discussions: 200,982, Posts: 2,379,842, Members: 246,344
Old April 18th, 2004, 12:08 PM   Digg it!   #1 (permalink)
No pants, Wearin'a Helmet
MitaDC's Avatar
Send a message via ICQ to MitaDC Send a message via MSN to MitaDC Send a message via Yahoo to MitaDC
Ok my dad who is just so very smart about computers {dripping sarcasm} bought an old lappy cuz, well I don't know why. Anyways so I turn it on and no os and also it likes to freeze . So went into the bios and made it so the cd-rom boots first but it never does. It shows like mouse initialized etc. then it says operating system not found. What do I need to do? Do I need to make Windows 98 bootable floppy's. I've never installed Win98 b4 so I have no clue but I would imagine I would just need to enter the CD. Anyways could anybody plz point me in the right direction? TY
BTW it is a Pentium 133mhz, 32mb ram
Dr. Cox -Newbie, Stay. Oohhh what a good boy you are, Newbie..... DEAR GOD JUDY HOW MUCH PRODUCT DO YOU USE?
J.D -None. It's like this when I wake up
MitaDC is offline   Reply With Quote
Old April 18th, 2004, 12:15 PM     #2 (permalink)
gambler2611's Avatar
most likely hard drive not plugged in or something funny like that. Does it show it up when it boots up on the bios?
Andy
Why should God make flowers beautiful if he can't just make humans like dull flowers? - me 18/1/2005
gambler2611 is offline   Reply With Quote
Old April 18th, 2004, 12:15 PM     #3 (permalink)
Boot disk sounds like a reasonable idea...
www.bootdisk.com
I'm Still Learning 24/7
MRCOMPUTER is offline   Reply With Quote
Old April 18th, 2004, 12:18 PM     #4 (permalink)
MitaDC's Avatar
Ok I will check, btw if it is disconnection how could i connect it back in? BTW yah it says On-Board IDE Drive 0 (None) wow shoulda noticed that right off the bat, ok next q how do I check if there is an hd so that I can plug it back in or find out that there isn't one at all (he bought it at an auction so u never know)
BTW it is a gateway2000 solo
Serial No: BC297314658
Old April 18th, 2004, 12:37 PM     #5 (permalink)
elroy's Avatar
Check in the bios that the IDE 0 is enabled, drive specs are listed or auto. If this is set to none that would cause your lappy to appear not to have a hard drive. Likely the lappy was sold due to mechanical failure or the owner was unable to make it go due to lack of knowledge.
Benjamin Franklin
elroy is offline   Reply With Quote
Old April 18th, 2004, 12:38 PM     #6 (permalink)
MitaDC's Avatar
Well I just went to the
On-Board IDE Drive 0 (None) sub screen and it is on auto
Autotype Fixed Disk [Press Enter]
Type: [Auto]
Cylinders: -
Heads: -
Sectors/Track -
Write Precomp: -
Multi-Sector Transfers: 16 Sectors
LBA Mode Control: Enabled
32 Bit I/O: [Enabled]
Ultra DMA Transfer Mode: Disabled
Transfer Mode: Fast PIO 4
I went looked in all the bays and unscrewed a compartment and all that was in there was ram, there is one empty compartment next to the battery. Maybe the HD is suppost to be in there?
Old April 18th, 2004, 12:44 PM     #7 (permalink)
MitaDC's Avatar
Type: [Auto] can be changed to [User] and it has tons of different hd configurations, maybe try using that?
Old April 18th, 2004, 12:56 PM     #8 (permalink)
MitaDC's Avatar
ok it sayed "Failure Fixed Disk 0" on the boot screen, I don't think it is there guys, anybody know where I could get one or where it would be on the laptop
Old April 18th, 2004, 01:27 PM     #9 (permalink)
The hard drive could be absent or bad...go into the BIOS and into standard CMOS setup...see if there is a hard drive showing in the primary position..if it says none, then the machine either does not have a hard drive, it is disconnected or no power...or is defective.
Laptop hard drives are usually accessed from a slot on the side that you must remove a panel. I had a P-133 Dell a couple of years ago, and the hard drive was on the left side near the bottom...furthest away from the screen.
Bovon is offline   Reply With Quote
Old April 18th, 2004, 01:31 PM     #10 (permalink)
Supporting our military
Bill in SD, CA's Avatar
http://accessories.gateway.com/Acces....htm?ref=merch
Bill
Edit: Whoops!! Didn't see the "out of stock" thingy. A lot of people must have bought used lappies without a hard drive.
Bill in SD, CA is offline   Reply With Quote
Is It Just Me? (3063)
Health Care Rationing (9)
Delete an OS (16)
Nvidia GTX 260 problem (9)
windows vista security holes (18)
Point and Shoot Camera Suggestions. (7)
Internet Lost (5)
updating BIOS via winflash, claims fi.. (0)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (38)
Dynex DX E-402 (3)
Delete an OS (16)
cell phone won't work (0)
Can't open Word (12)
