Thread: how to zero a hard disk
April 24th, 2004, 03:01 PM #1Junior Member
- Apr 2004
- 3
hello ,i have a problem with my computer after long and hard waiting trying to sort out my problem i found that the only best option is zeroing the hard disk but the only trouble i dont know how? can you help please ,thank you.
April 24th, 2004, 03:13 PM #2
Welcome to TechIMO!!
Either use the manufacturer's diagnostic disk to write zeroes or use Kill Disk - Hard Drive Eraser .
Bill
April 24th, 2004, 03:14 PM #3
Edit: Yeah bills way would be a lot easier then mines.
"You are only as wise as others perceive you to be." - M. Shawn Cole
April 24th, 2004, 09:21 PM #4Junior Member
- Jan 2004
- 24
Is zeroing a hard disk different than formating?
April 24th, 2004, 09:43 PM #5
yes. when you format, all the information about which files are stored on a disk and where they are stored is overwritten, but the files are still there. when you zero fill the hard disk, you write zeros to all the storage space on the disk, so the files are gone. but this means you need to format the disk to write information about where it can store files, so i guess a zero fill by killdisk should include a format, or would need one afterwards.
April 25th, 2004, 12:34 PM #6
Just as another option you can get this as well.
http://www.ultimatebootcd.com/
Wonderful tool to have and it has a lot of the manufacturers disks on it already plus a few zero fill utilities. Ive used it for that purpose and it works great.
April 25th, 2004, 12:54 PM #7
I was going to recommend Hitachi's utilities, but they may already be on the ultimate boot CD linked by crossedup. If not, Hitachi's utils (Drive Fitness Test) are more generic than most and will work with most ATA hard drives.
.bh."Our freedom depends on five boxes: soap, ballot, jury, witness; and, when all else fails, Ammo. " ?author?
April 26th, 2004, 08:12 PM #8Senior Member
- Jan 2003
- Location
- Connecticut, USA
- 816
completely erasing the drive's data sounds like a good idea for me...I'm going to be selling my mini-itx and including an 80gig drive with it...it's gone through several formats (it's now running Windows 98...after running Red Hat 8.0 with dual boot Win2k pro. I'd like to secure-erase the data before I turn it over to someone else.
my system specs:
Via C3 (not celeron) Samuel 800mhz cpu
512mb PC133/100 SD RAM
80GB Maxtor 7200rpm hdd
52x Lite-On CDROM/CD-RW
56k V.92/V.90 low-profile Winmodem
150W psu (internal)
China-made case...unbranded.
Directron case badge: "I Made This"
I should prolly post this in the resellers forum too. I'll entertain offers greater than $399, not including shipping. For a complete system, this is a great deal.
I'd like to be sure that none of my financial data nor personal details not pertaining to the actual sale be released via my hdd. I'll look into those utilities.
thanks!
~Branson
I'm an Eagle Scout! (1997)
December 25th, 2011, 03:39 AM #9Junior Member
- Dec 2011
- 1
ummmm to zeroing just need a reimage with the assambly 3 on pretest but, that is only with the provider, (FOXCONN, INVENTEC,CISCO, ETC) try pressing F12 quickly hwen he PC is booting after that press up arrow and selec TOASTER (DOS), with that write TACO Z(in the DOS window) press enter and disconnect the AC adapter and your HDD gonna be ZEROING
;D
December 25th, 2011, 04:14 PM #10
January 4th, 2012, 11:55 PM #11
That doesn't zero a hard drive.
Found it thanks very much!!!
SLI problem? :(
