P4 wont turn on
View Poll Results: Why p4 dont start on first try
Bad power supply 5 71.43%
Bad on switch 1 14.29%
bad cpu or ram 0 0%
its just sleepy 2 28.57%
Multiple Choice Poll. Voters: 7. You may not vote on this poll
Currently Active Users: 1293
Discussions: 200,929, Posts: 2,379,149, Members: 246,296
Old April 30th, 2004, 01:48 PM   Digg it!   #1 (permalink)
billniceguy's Avatar
Talking
P4 wont turn on
My P4/2.4 gig, 512 ram 98se wont start up until 3-4-5 times. Once it starts it is fine. Why wont it start first time? I push start button, red light for hard drive stays red and nothing happens...i hit reset and same thing, and reset again, and sometimes on 3-4-5 time it finally starts and works ok. Why wont it work on first try?
billniceguy is offline   Reply With Quote
Old May 1st, 2004, 11:16 PM     #2 (permalink)
Kuasimodem's Avatar
Send a message via MSN to Kuasimodem Send a message via Yahoo to Kuasimodem
Most likely, your power supply is either flakey or insufficient for your system.
Kuasimodem is offline   Reply With Quote
Old May 2nd, 2004, 12:02 AM     #3 (permalink)
norml.org
thekingofpain's Avatar
Have you got a 12v line going directly to the mb?
(wasnt included in the poll)
thekingofpain is offline   Reply With Quote
Old May 2nd, 2004, 12:10 AM     #4 (permalink)
I voted for the switch..u can easily check that aspect of it by opening the case...pulling the power switch wire off the motherboard and using a jumper to connect the pins instead.
Old May 2nd, 2004, 12:27 AM     #5 (permalink)
1010011010
jmichna's Avatar
Is the a system that was formerly working fine, or a newly built one that you just put together?
jmichna is offline   Reply With Quote
Old May 2nd, 2004, 12:42 PM     #6 (permalink)
jmichna..honestly cant remember. am 68 and poor memory. will try what john said..re line to mom, dont think there is one, but that good idea too. thanks all for your help, bill
Is It Just Me? (2869)
Obama the Muslim (14)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
