Printer connection; USB vs parallel
Currently Active Users: 2758
Discussions: 200,388, Posts: 2,373,134, Members: 245,719
Old May 2nd, 2004, 12:48 PM   Digg it!   #1 (permalink)
I have always used a parallel port for my printers. My first one didn't have USB, the onbe I have now does, but I use the parallel port since:
1. Is it mainly for a printer, I have nothing else that would/could us it.
2. Why tie up a USB port when the other decicated port is there and I have the cable?
BUT, is there:
1. Less processor usage using a USB port?
2. Faster data transfer (USB 1.1 that is)?
I notice when I send a larger 'job' to the printer it really 'chokes' the processor, maxes it out until the job is done. I don't know if it is a port issue or something else.
Specs:
2k, w/sp4 14 processes running at startup
AMD 2100b Throughbred
nForce2 MB
512 MB PC2700
videobruce is offline   Reply With Quote
Old May 2nd, 2004, 01:15 PM     #2 (permalink)
bailey's Avatar
first off,
I really don't notice any differance in printing speed with any of the ports, I use both usb, parallel, and network, all seam to be the same.
as for tying up a usb port, I would highly recommend that you use a self powered usb hub for the connections, as it will give you a greater number of ports to use and also remove any power draw from the motherboard usb supply.
I have 3 usb hubs on my system, and every thing works just great
bailey is offline   Reply With Quote
Old May 2nd, 2004, 01:35 PM     #3 (permalink)
links's Avatar
I use a USB 1.1 for my printer. It was the only option for me since the printer is about 5 feet away from the comp and the cable had to go through a few small holes. A regular parallel cable just wouldn't fit through the holes. I really didn't feel like drilling more holes. As for speed I havn't noticed a difference. There probably is a difference in speed but for the average job you probably wouldn't notice it.
links is offline   Reply With Quote
Is It Just Me? (1321)
Bloomberg Wins Narrowly Despite Meg.. (12)
Assosiations (21453)
Cost to add a server? (23)
UK Mineral Oil Supply? (9)
Delete an OS (5)
Should I jump from Vista to 7? (8)
asus 4870 hd dk 1gb ddr5 (12)
i7 Gaming Build (21)
Power Connectors (8)
Windows 7 Compatibility and activat.. (11)
Will COD4 work on my pc? (11)
Windows Easy Transfer (12)
Installing Optical SPDIF Port (10)
WoW Player Seeking Graphics Card Help (3)
"Scroll Lock" can't find on.. (30)
AIWA Z-R800 Compact disc stereo syste.. (0)
Windows 7 turns off aero (0)
Key code retreivers (2)
Frustrating anamolies on 8800 gtx (0)
Network Sharing access denied (1)
Windows 7 Wheres S3 Stanby? (1)
Delete an OS (5)
PC goes on... off... on... (2)
Lenovo Easy Capture compatible with W.. (0)
World's largest Monopoly Game using G.. (299)
graphic card suggestion (1)
Photoshop batch job - resizing images (21)
62 Processes Running in XPPro! (4)
vmware .OVF to ESXI conversion (0)
XP Configuration Error : "Code P.. (73)
What is the usual newegg shipping tim.. (26)
Fall-Winter Cleaning Sale (0)
1st ever Harddisk benchmark thread (86)
currently running without add ons dis.. (1)
Computer turns on then off again (1)
