Results 1 to 6 of 6
    Aug 2003
    Garland, Texas
    159
    Runtime error, running on winME
    i get this Microsoft Visual C++ runtime error, or something to that effect but thats pretty close, im just wondering what it is, it happens about 1 or more times a day i do a re-boot and its fine happens after an hour or more, happens pretty much only when im online. in the box it says abnormal termination,something to that effect, and it has to terminate explorer.exe. so i ctrl,alt,delete and reboot. doesnt happen when not in internet explorer, online looking at webpages, at least i think. it has happened so far when playing games. can anyone tell me what it is and if it can be stopped or avoided.
    <JiGGleS>
    INTEL QX6700 OC'D TO 3.1GHZ, EVGA 780I FTW, 8 GIG KINGSTON HYPERX DDR2, EVGA 8800GTX OC'D, X-FI PLATINUM
    Aug 2003
    Garland, Texas
    159
    well im at school right now but when i get home i will do so and hopefully it works, which it probably will so thanks ill post later to tell if it happened again or if it worked.
    <JiGGleS>
    <JiGGleS>
    Aug 2003
    Garland, Texas
    159
    ok...... well i did it in ie adn it still happens but i installed msn explorer and it doesnt come up. so unless anyone can help me with ie i will just keep using msn explorer, oh i got the full message down " Microsoft Visual C++ Runtime Library" then under it "C:\windows\explorer.exe" then under that "abnormal termination" it says that, and i know it doesn't happen on msn because thats what im using to type this, because when i use ie it happens. thaks if u can help.
    <JiGGleS>
    May 2004
    51
    Hi there,
    Any chance you can let me know when exaclty you get this error? Is it when you start a particular program/application?
    Thanks.
    Senior Member omalleytrading's Avatar
    Apr 2003
    Albany, NY
    623
    I had to read this thread, I thought maybe the fact that you were running Windows Me was the problem....
    Aug 2003
    Garland, Texas
    159
    well i get it when i open internet explorer and after i go to a few websites, and i dont think its becuase winme, my friend told me it was a problem with internet explorer version 6, cuz she had the same problema nd thats the version i have, she had to totaly delete the entire program, and reinstall version 5 and no problems.
    <JiGGleS>
