How to connect my computer to my cable modem?
Currently Active Users: 2281
Discussions: 200,970, Posts: 2,379,741, Members: 246,335
Old May 14th, 2004, 05:19 PM   Digg it!   #1 (permalink)
Ok i have a surfboard SB4100 Modem and it had both a usb jack and ethernet jack (Sorry if jack is wrong word) Anyways i currently have the usb jack connected to a computer and it is working fine. I am wondering if it is possible to hook up another computer to the ethernet jack and have them both working at the same time.
Also i have no idea how to set up the connection between the computer and the modem with the ethernet jack. Ive tried plugging it in with no success and not sure what to do
Thanks for the help,
Also asssuming i cant have both computers running at the same time anyone no of some good wired roaters they would recomend?
Flato is offline   Reply With Quote
Old May 14th, 2004, 05:47 PM     #2 (permalink)
omalleytrading's Avatar
FLato - I'm not sure that will work. My guess is that the modem expects you to use either the USB input or the Ethernet input, not both.
Of course, you can always try it.
If that does not work, just buy a hub. They're fairly cheap and it will allow you to "split" your cable connection up among a number of computer. Check with your ISP first to see if there are limits on how many computers can be attached to your account. RoadRunner allows up to 4 I believe. Your ISP may be different.
FYI, I recommend NetGear hubs. I've used them for years without a problem.
omalleytrading is offline   Reply With Quote
Old May 14th, 2004, 06:10 PM     #3 (permalink)
Vagabond's Avatar
Send a message via ICQ to Vagabond
That will not work the modem would not know which puter to send information to... you will have to get a hub you can find them cheap on deal websites and such....
Vagabond is offline   Reply With Quote
Old May 14th, 2004, 10:33 PM     #4 (permalink)
Kuasimodem's Avatar
Send a message via MSN to Kuasimodem Send a message via Yahoo to Kuasimodem
Actually, in the manual for your SB5100 on page 40, it explains how to connect two computers, one on each port, to the modem. The only drawback is that each port needs an IP adress from your ISP
Your only other option is a router, not a hub. The router will get an IP adress from the ISP and then give each computer its own internal IP (192.168.xxx.xxx). This is NAT, or Network Adress Translation, which is a basic type of firewall protection. It isn't the greatest, but it does afford protection from all but the most dedicated hacks.
Dlink, Linksys, Netgear. They all make great routers, and you should be able to find a good 4 port in the $50 or less range.
BTW - DON'T connect both the ethernet and USB connections to the same computer, you won't get any connection at all.
Kuasimodem is offline   Reply With Quote
Old May 15th, 2004, 01:52 AM     #5 (permalink)
not quite you can buy a hub and ask your cable provider for
another ip address for the other computer but may cost you
about 7-10$ more
but a router is the way to go as mention above
electric is offline   Reply With Quote
Old May 15th, 2004, 02:48 AM     #6 (permalink)
HeadBand's Avatar
what kuasimodem said is right on i have a sb4100 and it says the same thing it will if your company supports it
afaik not many companies will give out a second ip and the ones that do charge 20-30 $ extra because both will be able to use full bandwidth
Old May 19th, 2004, 03:48 PM     #7 (permalink)
That's not necessarily true.
If the ISP allows for multiple computers on one account, its DHCP server will issue a unique IP address to each computer.
want to broadband... nerdgirl Networking and Internet 3 January 23rd, 2004 11:11 AM
networking 2 pc's w/ cable connection brianl0202 Networking and Internet 2 October 3rd, 2003 11:24 AM
Surf net at same time on two PC 50FT apart? Trophy1 Networking and Internet 12 June 24th, 2003 08:59 AM
NetworkCard 10Mpbs...can this be theonetruegod Networking and Internet 10 March 7th, 2003 05:26 AM
HUGE Problem. Need a little help?? kruseman Networking and Internet 26 December 28th, 2001 03:26 PM
Is It Just Me? (3045)
Breaking: San Diego ACORN Document .. (10)
The disrespect of Obama by Russian .. (47)
Delete an OS (15)
Nvidia GTX 260 problem (7)
Internet Lost (5)
Can't open Word (12)
Delete an OS (15)
Open With ..... Win7 (3)
Internet Lost (5)
virus blocking exe. files (1)
Print spooler problem (16)
webcam (0)
