PC wattage and amps
Currently Active Users: 1723
Discussions: 200,510, Posts: 2,374,411, Members: 245,833
Old June 8th, 2004, 06:12 PM   Digg it!   #1 (permalink)
PC wattage and amps
[undefinedundefined[font=Arial][size=7]
Hello , could any one tell me the watts and amps needed for 13 puters. Iam trying to find what we can use for an african school where electricity cuts out 10 times a day! any suggestions welcom
Thank you
crainville@ pacificcoast. net
andree 33 is offline   Reply With Quote
Old June 8th, 2004, 07:24 PM     #2 (permalink)
wju425's Avatar
Welcome to TechIMO!
That's an unusual request. With power outages like that I think you need UPSs and several of them. UPS stands for Uninterupted Power Supply. Maybe someone here has a better idea. They'll be along shortly.
\o/ Billy
wju425 is offline   Reply With Quote
Old June 8th, 2004, 08:14 PM     #3 (permalink)
How about a gas generator .... like the hospitals have ..... that kicks in automatically if the power cuts out for any more than a minute..... so that they have a long term Uninteruptable Power Supply (UPS) ..... unlike the standard UPS that only lasts a few minutes ..... giving you just enough time to shut down the system. Of course, you also need a UPS for each system to keep it going till the generator starts up .....
Peeety is offline   Reply With Quote
Old June 8th, 2004, 08:51 PM     #4 (permalink)
Amperage at 120 VAC will be (plus or minus) 10 amperes each...that will be somewhere around 120 to 130 amperes total. Since wattage is a function of volts times amperes (P=E X I) the wattage for this kind of setup should be close to 15,000 watts.
Bovon is offline   Reply With Quote
Old June 8th, 2004, 08:55 PM     #5 (permalink)
Perfetc Member
VHockey86's Avatar
The average AC current consumptions of a single PC is only going for be a couple amps.
VHockey86 is offline   Reply With Quote
Old June 8th, 2004, 09:17 PM     #6 (permalink)
I'm silently judging you
ArcticFox's Avatar
Send a message via AIM to ArcticFox Send a message via MSN to ArcticFox Send a message via Yahoo to ArcticFox
You are asking a difficult question, my friend.
I think there are two ways to find out - first, we need to know every part, model number, and size of all the components in every computer. EVERYTHING.
Or, alternatively, you could buy one of these, a Watts Up? or Watts Up? Pro:
http://www.dom.com/products/wattsup/index.jsp
Slap it on a PC, fire up an intense benchmark, and see what it's sucking. Repeat on all systems. Also, open Notepad so it's a huge span of white (white takes the most power for a CRT, all guns are firing versus a black screen, no guns are firing) and see what the monitor does.
ArcticFox is offline   Reply With Quote
Old June 8th, 2004, 10:25 PM     #7 (permalink)
No matter how you cut it, power (in watts) is still equal to volts times amps.
P = E (volts) X I (amps) ~ Watts
P = 120 X 2 = 240 watts (your couple of amps from above).
Somehow.. I don't think so. Any of todays full sized computers consume more than 240 watts.
10 amperes was of course an exaggerated calculation...which good processing of unknowns is always employed. Usually, an engineer will double the amount expected when he (1) does not know exactly what will be used or (2) the equipment will be used in an environment that can allow upgrading in the future.
Old June 8th, 2004, 11:09 PM     #8 (permalink)
ben-the-slacker's Avatar
Doesn't that sorta depend on how much power computers suck? The way I learned it in physics, P=I*V (Watts=Amps x Volts). So if you have 13 computers using a 200W psu each with a 80W monitor, and the voltage is 220, then you'd get ~16.5amps total. Right?
ben-the-slacker is offline   Reply With Quote
Old June 8th, 2004, 11:25 PM     #9 (permalink)
Send a message via AIM to RamonGTP Send a message via MSN to RamonGTP Send a message via Yahoo to RamonGTP
It won't be 10 amps, I can gaurantee that. It won't be 5 Amps either.
RamonGTP is offline   Reply With Quote
Old June 9th, 2004, 01:32 AM     #10 (permalink)
go out and buy an amp meter ,take the readings of the computers
when their fired up
amps x whatever voltage you are using = watts
no one here can answer your question with out more information but
you can do it yourself with an amp meter and do the math or
better still get an electrician to do it
electric is offline   Reply With Quote
Too many systems on one circuit? daveleau General Tech Discussion 34 February 27th, 2003 02:44 AM
Power Supply n3uxf Technical Support 3 November 1st, 2002 11:34 AM
Power down k7s5a - case study heda_p Motherboards 9 April 29th, 2002 06:12 AM
Athlon Power Draw? Arjay13 Processors, Memory, and Overclocking 15 February 14th, 2002 08:07 PM
Lapping of heatsink / Mobo Fan Header woodbutcher Processors, Memory, and Overclocking 2 December 17th, 2001 02:14 PM
Is It Just Me? (1635)
Review My Build (6)
Assosiations (21496)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
windows 7 retail and rtm (3)
boot from CD-ROM in chipset via P4M80.. (1)
Review My Build (6)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
