Page 1 of 2 1 2 LastLast
Results 1 to 20 of 39
    Member CJDMaster804's Avatar
    Jun 2004
    123
    My PC turned on by itself and I am scared
    Yep, after being off for 10 min it shut on by itself.
    Why/How would it do this??
    Sep 2002
    Iowa
    3,404
    Overheating...Virus...any number of things...what are your system specs? What is your CPU temp?
    Ultimate Member Undeadlord's Avatar
    Philadelphia, PA
    1,559
    Cunokyle,
    I think you read it wrong or maybe I did .. CJD, are you saying your system turned itself ON?
    Undeadlord
    Communal Member Detritus's Avatar
    Jan 2002
    MI
    25,853
    4
    My computer was doing this before and killing hard drives. That was when I took it apart and found several swollen and leaking caps on the motherboard.
    Sep 2002
    Iowa
    3,404
    Quote Originally Posted by cunokyle
    ooo...I did read that wrong!
    Steeler Fan jman01pa's Avatar
    Louisville KY
    3,251
    Go into the BIOS and turn off the "Wake on xxxx" or "Power on xxxx" functions/events
    Ultimate Member FatalException's Avatar
    Jun 2004
    Indianapolis, Indiana
    1,398
    If the above solutions don't work, I know this great group of people...
    1-800-GHOSTBUSTERS
    Ask for Peter or Egon, they know what they're doing...
    But really, I think it may be something with a short inside of your PC. Like someone else mentioned, it could be a leaking capacitor or the like. I'd suggest unhooking all components except your motherboard, RAM, video card, and fans. If your computer still turns itself on randomly, it is likely one of those 4 components or the power supply. If it stops turning itself on after unhooking your hard drives, CD-ROM's, expansion cards, etc, then it is likely an issue with one of them.
    Be sure to check the BIOS for that wake on time setting too!
    Ultimate Member LeftCoast's Avatar
    Sep 2002
    Tampa
    1,947
    Understandable. Not the most reader-friendly use of the English language.
    I'd disconnect from the net and see if it happens. If it does, Detritus may be onto something.
    Millions long for immortality who don't know what to do with themselves on a rainy Sunday afternoon.
    Susan Ertz
    Uncommon Man samwichse's Avatar
    State College, PA
    4,281
    I've got an old emachines that does the same thing, except even more randomly. It can be off for days and then at 2:30 in the morning "whiiiiir beep" and it's over in the corner turning itself on. I think I've narrowed it down to an intermittant short around the PCI slots (maybe the board grounding against the case) that sporadically shorts itself enough that the power supply (which is "shorted" to turn on in the first place, look at the ATX spec) turns on. My guess is a short against the case like that.
    Sam
    Louisville KY
    3,251
    Quote Originally Posted by samwichse
    Sam
    The scary part is that the pc isnt even plugged in.
    Senior Member nurdonsite2's Avatar
    Jan 2003
    Mississauga, Ontario
    604
    WTF???? lol
    Oct 2002
    Th3 De$k
    120
    Quote Originally Posted by FatalException
    1-800-GHOSTBUSTERS
    Uh, Its got no power? thats a new one...........
    ANywho. like so many have said before, remove everything but the basics, and seee what it does. also, you dont have any animals? cause i was sitting in my room once and my computer suddenly turrned on. i was like what in the world????? so i kept trying to figure it out, finaly i borrowed a buddies laptop powered with a small web cam, i made sure the area was lit while i was gone, (or home for that matter) and what did i see? one of my roommates cats walked by and brushed up against the tower (which sits on the floor) and accedently pushed the button. just a thought...
    Ollie
    faLLen
    Jun 2004
    123
    My cas isnt really into computers, Also, this hasnt happened since but when it turned itself on, I decided to let it boot and I checked my Email.
    After I chekced my email, I found an email that promised me I can increase my size of "that special part of the mans body" by %25!!!!! for only $19.99!!!
    So it was like meant to be by some higher power!!, the PC turned itself on then lead me to this amazing pill for only $19.99!!!
    WOW
    (AKA) Nakamura sweeper2's Avatar
    Nov 2003
    5,737
    do you leave your pc on 24/7, but like in standby or somthing, because the slightest touch of the mouse can turn it on, mine has done that several times, but i think the cat hit the desk and the mouse moved a bit or it could be a program kicking it on.
    i am assumming the pc is not fully turned off and turns itself back on (via the pwr button). If so...your **** out of luck on that one... ......."their here...Carolan...Carolan....."
  15. #15
    Feb 2003
    74
    Does it plug itself in?
  16. #16
    Louisville KY
    3,251
    I had an Epox mother board once that had an option in the bios that allowed you to turn on the pc by moving the mouse or selecting a key on the keyboard.
  17. #17
    Jun 2004
    123
    Yes it plugs itself in.
    lmao
  18. #18
    Nov 2003
    5,737
    do i smell a fib here.....hmmmmmmmmm
  19. #19
    FLAC Trooper ArcticFox's Avatar
    Jan 2003
    A theater near you
    5,424
    Funny you mention this kind of phenomena. Earlier today someone came over to my house and I installed a video card for him. While we were talking the phone rang.....
    And a week later........
    No, so my dad picks up the phone, and then after a bit hangs up........
    Maybe 2 seconds later....
    He says he heard me and the guy talking in my room......
    There is only one 900Mhz cordless phone in my room, no one touched it, it was on my bed sitting in the base station...... I seriously don't know what happened. My wireless router (2.4Ghz) was turned off at that time.
  20. #20
    Jan 2003
    Connecticut, USA
    816
    *--confused--*
    it's prolly a "wake on ____" issue. if your phone rings, it'll turn on, the computer thinking someone is trying to "dial-into" your system.
    sometimes if there's a power interruption, and you've set your computer in the BIOS to be "on" in the case of power failure, well there you go.
    it could be a hibernate mode, where your computer virtually shuts down, but is awakened by you dropping something on the floor (thus jarring the mouse, etc) which turns it on...
    I'd say check your Wake On ____ settings, and make sure nothing is set to remain "on" should an event occur.
    ~Branson
    and JP chicks dig guys with Einstein hair!
    I'm an Eagle Scout! (1997)
  1. Weird boot up...
    By ILC in forum General Tech Discussion
    Last Post: January 5th, 2005, 01:23 PM
  2. help ahhhhhh!!!! quick
    By Spidrex in forum General Tech Discussion
    Last Post: August 5th, 2003, 08:00 AM
  3. If ya dont see me...
    By korgul in forum Applications and Operating Systems
    Last Post: May 21st, 2002, 10:14 PM
  4. Anyone here afraid of flying ?!?
    By Skywalker[TSG] in forum IMO Community
    Last Post: April 12th, 2002, 12:55 PM
  5. Tanya Harding Paula Jones boxing
    By maface in forum IMO Community
    Last Post: March 15th, 2002, 11:55 AM
