July 23rd, 2004, 03:11 AM #1
What are the differences between straight cable and crossover cable?
Hi all,
I am just wondering what the actual differences a between straight cable and a crossover cable are? Speed, connection, struture, etc. ?
Theoretically, a straight cable is used to connect a computer to a hub whereas a crossover cable is used to connect 2 computers directly. But what I have noticed so far is that a crossover cable can be used to connect the computer to the hub too. I'm not sure abt whether straight cable can be connected 2 computers directly?
Are there any ways to recognise 2 different kinds of cables physically (without connecting to the computer)?
If anyone knows abt it, pls feel free to share with others.
Thanks,
Oyster
July 23rd, 2004, 03:18 AM #2
Look at the pinout of the cables. Here you can see them diagramed.
http://www.winnpsb.org/Tutorials/RJ45/default.htm
And a straight cable will not work to connect two computer together.
JkrohnSignatures blow hard
July 23rd, 2004, 04:03 AM #3
http://www.makeitsimple.com/how-to/dyi_crossover.htm
like jkrohn said, crossover used to connect to PCs directly together, also used for connecting networking devices together like Switch to Switch etc.
July 25th, 2004, 11:02 PM #4
Thanks a lot for this info, jkrohn and BeatYouWithShoe. It explains to me a lot about problems I met. Thanks again
July 25th, 2004, 11:35 PM #5Ultimate Member
- Oct 2001
- 10,821
there is no difference as far as speed etc
the crossover crosses the send and rx wire...otherwise if there are 2 nics they will both be trying to send on the same send wire etc...that is a real non technical way to look at it.
the way I think of it is that straight cables connect two DIFFERENT types of devices..whereas crossover cables connect two of the SAME type
so a nic to a nic needs a crossover cuz they are the same
a nic to a hub uses a straight
a hub to a hub uses a crossover
now..to make it more confusing they often have ports on hubs and routers called "uplink" ports....these uplink ports do the job of the crossover cable...so if you come from the uplink port of a switch to another switch you dont need a crossover cuz the uplink did the "crossing" for you
now if you come from an uplink port you are supposed to just go to a regular port on the next hub...if you go from uplink port to uplink port you have "crossed" it twice so in effect it is now 'uncrossed' again so you STILL need a crossover cable, lol
and to FURTHER complicate it...now they have a feature on lots of switches and hubs etc called "auto-mdix" or "auto mdi/mdix"....that is the new thing where it doesnt matter what kind of cable you use, lol..cuz it will just auto detect the proper connection type no matter which cable you use.
JP"Even a fool is thought to be wise if he is silent"
May 31st, 2012, 05:22 PM #6
June 21st, 2012, 09:55 AM #7
Simple
Straight - Used for everyday daily use, connecting from your hub to your computer
Cross-over - Used for connecting two PC's/Laptop or Switch to Switch - basicially you can create a mini local network and share file's, Ive had it setup at my home. basically a small file server.
Newbie Question: Connecting 2 PCs
By Ymer in forum Networking and InternetReplies: 38Last Post: April 23rd, 2004, 01:20 AM -
crossover cable with router causes problems?
By nurdonsite2 in forum Networking and InternetReplies: 17Last Post: December 29th, 2003, 11:02 AM -
Crossover Cable Help
By CrazyCase in forum Networking and InternetReplies: 6Last Post: March 6th, 2003, 08:11 PM -
Trying to Setup and make operative a simple two Computer Network
By leart3 in forum Networking and InternetReplies: 16Last Post: July 13th, 2002, 07:25 PM -
Setting up a Network, connecting hubs.
By surreal in forum Networking and InternetReplies: 3Last Post: February 4th, 2002, 01:04 PM
You can try to recover data by yourself first. Data recovery service is exspensive, some recovery software can help you recover formatted data at home, try to know more from here: Formatted hard...
How to recover data from FULL...
