Right mouse-click lag  | | |
August 9th, 2004, 02:58 PM
i am running windows xp pro (no SP), AMD 2000+ 768MB PC2100 (3x 256MB), Giga-byte GA-7VAXP. When I right click on a folder of any kind, the window quits responding for a couple minutes, if not more. If i let this window sit like this for that long, ti comes back to normal, but i can't right click. I am a gamer, I limit what runs at start-up to save resources. Attached are pictures of all the processes i have running, and also of msconfig and what i have disabled. I read through this thread: http://www.techimo.com/forum/t115639.html But i am not having the 100% cpu usage like this guy was. Thanks for any help and elt me know if you need more information.
GA-7VAXP Ultra
WD 180GB 7200RPM
Razer Diamondback
SyncMaster 710T
GF FX 5900 Ultra
512MB RAM
Athlon XP 2000+ @ 1850Mhz
Corsair HydroCool 200 EX
August 9th, 2004, 03:14 PM
Btw, i think that you have to login to Yahoo! to see the pictures. |
August 9th, 2004, 03:20 PM
| | Banned
Have you checked the mouse button settings? |
August 9th, 2004, 06:17 PM
and what am i looking for |
August 9th, 2004, 07:04 PM
I have that same problem when I want to copy stuff over, or right-clicking in general. I hope someone can offer the correct solution.  |
August 9th, 2004, 07:13 PM
| | ska7ing away.....
try this................it might not work
ok right click on...................only kiddin :P
really
go to control panel double click "mouse" and crank up the double click speed...........see if that works |
August 9th, 2004, 07:22 PM
| | Banned
Depends on the mouse driver. e.g. When you open the mouse utility you should see a tabbed window. One of the tabs (again depending on your mouse and its driver) will give a dialog box in which you can change the functionality of buttons, wheel, or whatever.
Also check device manager for the mouse for more options. Since the mouse support is with three or so drivers, you have the choice of looking at your backup, if you have one, or you can uninstall the mouse, boot, and the mouse should reinstall. Hopefully, that will cure your problem. |
August 10th, 2004, 01:46 AM
bumping up the double click speed didn't fix it, and i tried uninstalling/rebooting/reinstalling mouse, didnt fix either.. hmm, any more ideas? |
August 10th, 2004, 02:06 AM
| | The FNG
What anti-virus program are you running? I know that NAV is a resource hog. I used to use it and eventually gave it up for AVG 6.0 and now my right clicks are instantaneous. |
August 10th, 2004, 10:50 AM
I think this problem was traced to a specific update to Norton AV.
I had the same deal for a day. after subsequent updates it went away. |
