Results 1 to 5 of 5
    Aug 2004
    2
    Angry NEED HELP burning dvds please
    i just got a new computer with a 8x dvd burner with double layer write but i have so far been unsuccessful burning any copywrited movie. I just want to make some backup copies of my movies but the CSS-encryption will not let me.
    Can anyone suggest any freeware i can easily use to make copies of my copywrited movies?
    I have used a prog called "smartripper" to rip the copyrighted matieral onto my computer. I just need to know how to fit it on a blank dvd correctly?
    Please someone help me!
    Ultimate Member crazyray's Avatar
    1,228
    Arrow
    Try DVD Shrink. Then burn with NERO.
    Aug 2004
    2
    hey thanks alot. i used smartripper then dvd shrink and then record now and it worked wonderfully. dvd shrink was definately the program i was missing.
    Ultimate Member yohon125's Avatar
    Jan 2003
    Cary, NC
    1,350
    i use dvd decryptor to rip. clone dvd tocompress if needed and then burn.
    Member computerwizz's Avatar
    Jun 2004
    430
    This thread might help you as well pdoub01.
    http://www.techimo.com/forum/t114215.html
  1. Help - Nero/burning
    By shampoo in forum Applications and Operating Systems
    Last Post: April 20th, 2004, 02:12 AM
  2. LITEON 8X Dual-Format Rewritable DVD Drive (LDW-811S/8)
    By unclebob in forum Multimedia and Audio
    Last Post: February 21st, 2004, 01:32 PM
  3. Recommend DVD copying software
    By SeanC in forum Applications and Operating Systems
    Last Post: January 29th, 2004, 09:46 AM
  4. Sony DRU-510A Compatible Media?
    By omalleytrading in forum Storage Related
    Last Post: August 26th, 2003, 06:19 PM
