led lights on tower  | | |
August 22nd, 2004, 11:05 PM
#11 (permalink)
it says here, System Power LED 3-1 Pin PLED GREEN? |
August 22nd, 2004, 11:07 PM
#12 (permalink)
| | Perfetc Member
ok, that means the two power LED conections have to go on pins 1 and 3.
Is there any kind of a picture in your motherboard manual?
What exactly is the model of your motherboard? Maybe someone here can try to help you interpet the diagrams/manual (if its downloadedable at least). |
August 22nd, 2004, 11:08 PM
#13 (permalink)
there is a pic, of the hole thing, then they cirlced where this stuff is, and mobo is ASUS P4P800S |
August 22nd, 2004, 11:09 PM
#14 (permalink)
note-umm you said it has to go in pin 1 and 3, its 2 wires, and theyre joined to a black connector? theres 2 sets of 2 wires loll if that makes sense |
August 22nd, 2004, 11:10 PM
#15 (permalink)
| | The FNG
Well since you didnt say you have a problem with your switches, the power and reset, then leave those two alone. The only ones I would try switching and making sure they are on the correct pins are "Power LED" and "Hard drive activity lead." (should that be hard drive led?) Anyway, there are two wires for each led, usually one colored wire and one white wire. The colored wire usually goes on the positive pin (+) and the white wire goes on the negative pin. |
August 22nd, 2004, 11:12 PM
#16 (permalink)
theres one white wire, 2green, 2black, and a purple. |
August 22nd, 2004, 11:15 PM
#17 (permalink)
| | The FNG
You only have two leds right? So how do you have 6 wires? Should only be four. Disregard the power and reset switches for now.
Also to identify the positive led, on the little back connector that connects to the pins is a little arrow on either side of the connector.
I'm gonna take a look at your manual right now. Will be back. |
August 22nd, 2004, 11:18 PM
#18 (permalink)
| | Perfetc Member
The reason he has 6 is b/c he prolly hasnt hooked up the speaker wire (or maybe no reset button?). Although with some of those newer mobos maybe not. That particular mobo has case intrusion detection and stuff, so it could be for that
This is from the asus website for your mobo. Just match stuff up and you should be good to go.
August 22nd, 2004, 11:23 PM
#19 (permalink)
umm can i ask whats that case intrusion? |
August 23rd, 2004, 01:05 AM
#20 (permalink)
AHHHHHHHHHH... i pooped my pants now (jk) um...the computer doesnt start up now???/ i put the POWER wires into the first slot, and the HDD in the set of slots right below it, and i set everythin up, and pushed the power....NOTHINg. so then i switched the POWER back to where it was, and still doesnt fire up ..ahhhh omg..this can be fixed right..the computers not even 3 weeks old...*crys*
oh and another thing. theres two other wires, not connected to eachother, thers one green and the other black, theyuer just singles...?? |
