First build, any comments?
Currently Active Users: 1458
Discussions: 204,534, Posts: 2,419,685, Members: 249,954
Old August 30th, 2004, 03:09 PM   Digg it!   #1 (permalink)
This will be my first ever build, so any comments and suggestions would be welcomed, perhaps some good luck monkeys as well.
CASE: COOLER MASTER Praetorian Black ALUMINUM MID-TOWER CASE, Model "PAC-T01-EK" -RETAIL
PSU: Fortron 530W Power Supply, Model "FSP530-60GNA" -RETAIL
CPU: AMD Athlon 64 3200+, 512k L2 Cache, The Only 64-bit Windows Compatible Processor - Retail
MOBO: SOLTEK "SL-K8AN2E-GR" NVIDIA nForce3 250Gb Chipset Motherboard For AMD Socket 754 CPU -RETAIL
MEMORY: OCZ Enhanced Latency Serices 184 Pin 512MB DDR PC-3200 - Retail
VIDEO CARD: eVGA nVIDIA GeForce 6800GT Video Card, 256MB GDDR3, 256-Bit, DVI/TV-Out, 8X AGP, Model "256-A8-N344-AX" -RETAIL
HARD DRIVE: SAMSUNG 120GB 7200RPM SATA Hard Drive, Model SP1213C, OEM Drive Only
CD/DVD Drive: Lite-On Black 52X32X52X16 Combo Drive, Model SOHC-5232K BLACK, Retail
FLOPPY DRIVE: Samsung Black 1.44MB 3.5inch Floppy Disk Drive, Model SFD321B/LBL1, OEM Drive Only
MODEM:
Zonet V.92 56K PCI Data/Fax Modem, Model ZFM5620-CF - Retail
KEYBOARD/MOUSE: Microsoft Black Multimedia Keyboard & Wheel Mouse Optical Bundle PS/2 102keys -OEM
SPEAKERS: Creative SBS330 2.1 Speaker -OEM
Total: $1216.47
The system will generally be used for gaming and other basic stuff. I don't plan to overclock but might in the future. I also plan to pick up another 512MB stick of memory later, had to sacrifice one along with a kidney for the Gefore 6800 GT. I didn't get a DVD burner because I don't see myself needing it. So any compatibility issues, will I need anything else?
Also, one question, I've read up on how static electricity, ESD I believe, may damage your components and I've read various ways to resolve the issue, such as just touching the unpainted part of the case every ten minutes or so, any definitive solution to this? Or can I do just that, because it seems the easiest. Anyway, thanks for any feedback.
Grind Penitence is offline   Reply With Quote
Old August 30th, 2004, 03:18 PM     #2 (permalink)
Ive never had any issues with static...usually if you just keep a hand touching the unpainted part of the case you are good..so touch the case when you are toching the ram etc....try not to touch the metal contacts of the ram of vid card or pci cards or the back of the motherboard etc
Old August 30th, 2004, 03:18 PM     #3 (permalink)
BattleToad's Avatar
Send a message via AIM to BattleToad
All I got is:
1. Modem...you actually still use a dial up connection? Your mobo has onboard lan.
2. Go with a better speaker set, your mobo has onboard 6 channel sound. Go with the Logitech Z640's, you can get them for 37.99 and you'll have quality surround sound instead of crappy 2.1 channel.
3. I've havent used a floppy drive in like a year.
Other than that, looks good. As for static, the best advice I can give you is if your ordering in chunks, piece here piece there, then dont open any static sensitive parts (ie mobo, video card, etc.) till you get everything there and are ready to build. Good luck though, and welcome to TechIMO.
BattleToad is offline   Reply With Quote
Old August 30th, 2004, 03:22 PM     #4 (permalink)
Originally Posted by BattleToad
All I got is:
Still on dial-up. That's why there's no need for a DVD burner, can't download porn and whatnot. I heard floppy drives were needed to install sata drivers for the hard drive, but it's not going to hurt with it costing less than ten dollars.
Old August 30th, 2004, 03:25 PM     #5 (permalink)
hard drives are nice for bios flashes also and for using norton ghost etc
Old August 30th, 2004, 03:26 PM     #6 (permalink)
Moderator
phenious's Avatar
Send a message via AIM to phenious
yes, keep your floppy if you have sata drives or you want to use RAID.... or you wanna flash your bios....Good build though
phen
phenious is offline   Reply With Quote
Old August 30th, 2004, 03:26 PM     #7 (permalink)
The Real Bingo's Avatar
A floppy drive will be needed for SATA hard drives - you need to install the MOBO drivers. It can't hurt to spend a few bucks for a valuable floppy drive.
The Real Bingo is offline   Reply With Quote
Old August 30th, 2004, 03:48 PM     #8 (permalink)
TechKnickle's Avatar
Send a message via AIM to TechKnickle Send a message via MSN to TechKnickle
You can prevent ESD damage by wearing an anti-static wriststrap. You can get one for like $5.00 at Best Buy or Radio Shack. The thing with ESD is that you wont ever completely wipe out a component, but it will much more likely become unstable and lock your system if there was an ESD episode.
TechKnickle is offline   Reply With Quote
Old August 30th, 2004, 03:53 PM     #9 (permalink)
Father V2.0
washe's Avatar
Send a message via MSN to washe
Just dont make your build on a carpet floor, this will reduce the risk of ESD.
I havent got any ocurrences with ESD but It can happen, you just need to be grounded properly, a anti-static wriststrp will do it....
remove any jewelery too.
someone is more skilled than you!
http://s7.bitefight.org/c.php?uid=23753
washe is offline   Reply With Quote
Old August 30th, 2004, 03:58 PM     #10 (permalink)
Heh, I put mine together on carpet. Blue carpet. Maybe it's the color that made it work.
Why is AMD better than Intel or is it? jongoo Processors, Memory, and Overclocking 119 April 10th, 2004 02:03 PM
New Computer Suggestions nickb General Tech Discussion 33 February 28th, 2004 11:58 AM
Who will build my PC? Warflagon General Tech Discussion 53 January 13th, 2004 08:08 PM
Odd stuttering / Freezing problems. Pyron Technical Support 20 May 1st, 2003 08:11 PM
Help me buy HD, plz joker_927 General Tech Discussion 6 March 27th, 2003 01:48 AM
Is It Just Me? (1639)
An Inability to Be Civil (23)
newegg=bad people (32)
USB not recognised..... (16)
Need some suggestions on building a.. (35)
Recent Problem (15)
First time builder (6)
HTML (7)
[ F@H Chat] 03/07/10 New Month New.. (92)
Motherboard the culprit? (7)
Windows XP Pro Error log (9)
Suggestions? (6)
scsi drive raid 5 small business serv.. (0)
2000 IT Certification Exams for FREE (0)
Common Ports for Networking (18)
Message from webpage (2)
Microsoft removes hardware virtualiza.. (2)
How to transfer iPod files to iPod/Co.. (0)
pc won't start (2)
Need some suggestions on building a g.. (35)
Processor speeds? (20)
Outlook keeping 2 copies of sent mess.. (3)
Recording Audio from a website? (8)
SSH Tunnel Or OpenVPN? (2)
TV tuner (1)
C# Sql Server 2005 Connection Issue (0)
GOM Player with Google Chrome? (0)
First Time PC Builder (Gaming PC) (1)
[ F@H Chat] 03/07/10 New Month New T.. (92)
HTML (7)
re laptop (1)
