building first rig
Currently Active Users: 2661
Discussions: 200,998, Posts: 2,379,968, Members: 246,365
Old September 13th, 2004, 01:14 PM   Digg it!   #1 (permalink)
swell22's Avatar
building first rig
ok im about to order parts for my first computer build. Will you guys help me make some final decisions and let me know if everything is compatible? The only thing i havent finalized yet is the psu, mobo, and case. Here is everything:
case: leaning towards the kingwin
http://www.newegg.com/app/viewProduc...ion=11-112-040
http://www.newegg.com/app/viewProduc...ion=11-170-012
mobos: need help here
http://www.newegg.com/app/viewProduc...ion=13-130-468
http://www.newegg.com/app/viewProduc...ion=13-131-510
vid card:
http://www.newegg.com/app/viewProduc...ion=14-130-203
psu: http://www.newegg.com/app/viewProduc...ion=17-152-014
or http://www.newegg.com/app/viewProduc...ion=17-153-007
cpu: http://www.newegg.com/app/viewProduc...ion=19-103-463
memory: will get another stick later
http://www.newegg.com/app/viewProduc...ion=20-144-305
harddrive: http://www.newegg.com/app/viewProduc...ion=22-152-017
keyboard mouse: http://www.newegg.com/app/viewProduc...ion=23-109-122
will get monitor and sound and everything later
swell22 is offline   Reply With Quote
Old September 13th, 2004, 01:34 PM     #2 (permalink)
swell22's Avatar
oh ya
or this psu
http://www.newegg.com/app/viewproduc...153-014&DEPA=1
Old September 13th, 2004, 01:53 PM     #3 (permalink)
the *Voice* in your Head
PresterJohn's Avatar
on the mobo side, the MSI board is tops w/the nF3 chipset. i'd pick that over the asus unless you specifically needed PATA raid.
on the cases:
i really like the lianli. you got 4 fans on that sucker - incl. 2 on the drive bays and very importantly, a top blowhole. the kingmax description lists 3 80mm fans but in the pics, i can only see 1...also no top blowhole.
Old September 13th, 2004, 02:00 PM     #4 (permalink)
oh...on the PS:
avoid the Raidmax...weak 12v rails. no power specs on the w0022...probably similar to the w0014. unless you needed a dead-quiet machine or want glow-in the dark fans, i'd save the $20 and buy the w0014.
Old September 13th, 2004, 02:02 PM     #5 (permalink)
swell22's Avatar
thanks
thats what i was looking for. I was just leaning towards the kingwin b/c ive heard the lian li blocks the psu so if you get one that has any light it wont show...but thats not that big of a deal so ill probably go with the lian li
Old September 13th, 2004, 02:02 PM     #6 (permalink)
Send a message via AIM to Jokerswild
I would definatley go with an MSI board over an ASUS board unless you are dead set on it. While it's been a while since I've built a computer, I've had 3 MSI boards and they have all done extremely well. Also good choice using www.newegg.com . They offer excellent service.
my two cents.
You know we expect pics when you get that thing assembled. Good luck!
Jokerswild is offline   Reply With Quote
Old September 13th, 2004, 02:05 PM     #7 (permalink)
swell22's Avatar
i dont know anything about the rails and such. Is that w0014 a good enough psu? will it have enough power? or would you guys suggest something else
Old September 13th, 2004, 02:07 PM     #8 (permalink)
good choice.
i'm currently using a lianli pc7 on my main box - dual cpus, 4 hds, 2 cdrw/dvd drives, 1agp/5 pci cards inside it...no problems with heat and it's not noisy either (3 case fans).
Old September 13th, 2004, 02:10 PM     #9 (permalink)
relax...the w0014 is more than enough.
the 3.3v and 5v specs are plenty...18a on the 12v rail will cover you as well.
Old September 13th, 2004, 02:11 PM     #10 (permalink)
480w of juice is enough in my book unless you plan on running something on the extreme side. If you plan on just modding the thing that would definatley be enough for lights and all. My first machine I put all kinds of lights and meters along with 2 hdd's, a CD drive, floppy and the extra Sound Blaster Audigy2. Not to mention the Mobo and processor and I've never had a problem with just the 200watts that PSU put out.
[POLL] How fast is your computer ? crouse Processors, Memory, and Overclocking 384 February 1st, 2005 01:00 PM
Dell 2.6g P4 800FSB 17" LCD $689 w/free S&H Richard Cranium ResellerRatings Homepage Deals 6 January 29th, 2004 12:25 AM
case wrap thePh@r@oh PC Modification 9 September 25th, 2003 10:50 AM
Problem installing winxp/win2k jl123 Technical Support 22 October 22nd, 2002 02:55 AM
Power Supply Question reever General Tech Discussion 12 June 26th, 2002 12:28 PM
Is It Just Me? (3100)
Health Care Rationing (17)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Laptop with wireless problem. (13)
[F@H SPAM 11/16/09] ! 1/2 months to.. (41)
Delete an OS (18)
add ram to existing (3)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (41)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
cheap gaming laptop? (12)
