mouse moves, but i don't move it..help???
Currently Active Users: 1436
Discussions: 200,931, Posts: 2,379,159, Members: 246,297
Old September 17th, 2004, 12:56 PM   Digg it!   #1 (permalink)
(AKA) Nakamura
sweeper2's Avatar
Unhappy
i have a 2button plus (wheel) mouse "GE"...and for some reason, i can not be touching it and the curser will just start moving...it does it erraticlly and i don't have any pattern to explain on it...?? Doesn't Win XP install drivers (just did a new install) ...
this also affects my screen saver due to i have it set up to pwr down the monitor then shut down the HD after an hour, but when the mouse decides to move on it's own it turns everything back on...grrrr
P4 3.0ghz , P4M900-M4 , 450 psu , Sapphire HD 3850 512mb with an Accelero S1 cooler , 2gig pc5300 ddr2, 80gig Deskstar , 16x dvd-rw
Old September 17th, 2004, 01:14 PM     #2 (permalink)
Uncommon Man
samwichse's Avatar
I'm guessing that this is an optical mouse? You need a surface with better contrast and detail.
I call that phenominon "mousewalk" in optical mice.
Sam
samwichse is offline   Reply With Quote
Old September 17th, 2004, 01:21 PM     #3 (permalink)
Hungrycookpot's Avatar
Send a message via MSN to Hungrycookpot
yeah you could also have some liquid on the lens, ive noticed that if you set the mouse on some water or something, the liquid nature of the water and the refraction in the water makes it do this.
If its a mouse ball, well... its possessed
Hungrycookpot is offline   Reply With Quote
Old September 17th, 2004, 01:33 PM     #4 (permalink)
(AKA) Nakamura
sweeper2's Avatar
it's not an optical mouse, just a standard ball mouse...on a flat wood desk, does it on the desk and on the mouse pad...
it only started after i did this new install with SP2
Old September 17th, 2004, 05:19 PM     #5 (permalink)
Check the manufacturer's web site for recent driver updates.
jjakobsen is offline   Reply With Quote
Old September 17th, 2004, 06:13 PM     #6 (permalink)
Pamlor's Avatar
The main question does it do the samething whit an outer mouse, if so it chould be an virus maybe.....
If not it is just something wrong whit the mouse......
Pamlor is offline   Reply With Quote
Old September 17th, 2004, 06:32 PM     #7 (permalink)
It's the cheese guy! ¬_¬;
paul9's Avatar
Send a message via MSN to paul9 Send a message via Yahoo to paul9
i think your mouse is just interpreting borderline voltage variations as a full state change, instead of ignoring them. possibly a less than optimal tie to ground on one of the components or logic gates. try a new mouse. make sure it is a optical one. no more gummedup rollers to clean. precise and smooth. bliss.
No man's life, liberty, or property are safe while the legislature is in session. --Mark Twain (1866)
paul9 is offline   Reply With Quote
Old September 17th, 2004, 08:29 PM     #8 (permalink)
(AKA) Nakamura
sweeper2's Avatar
might try a new mouse...this one is in great shape...pretty new...just odd why it does it..the ball is clean and there is nothing on the inside rollers to clean off...odd...but i think a new mouse might be in order then...
Old September 18th, 2004, 03:49 AM     #9 (permalink)
ryanredbaron's Avatar
Send a message via AIM to ryanredbaron
that happens to me to all i can say is windows lol
ryanredbaron™
www.ilovellamas.com
ryanredbaron is offline   Reply With Quote
Mouse laags on slow movement? cMoAyRoItOe Technical Support 2 July 27th, 2004 12:28 AM
Favorite 'Puter Pranks? Tomteriffic Applications and Operating Systems 56 May 24th, 2004 09:23 PM
Are all optical mice as crap as MS VERT General Tech Discussion 36 August 15th, 2002 07:50 PM
Weird Mouse Behaviour Agent_Embryo Technical Support 4 February 11th, 2002 06:32 PM
Is It Just Me? (2872)
Obama the Muslim (14)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
