Corless Drill Battery Charger Kaputz!
Currently Active Users: 2644
Discussions: 200,520, Posts: 2,374,503, Members: 245,842
Old September 18th, 2004, 03:40 PM     #11 (permalink)
I am a banana!
originel's Avatar
Send a message via AIM to originel
Well out of that crop firestorm is the only real budget drill. I've seen it happen to skills and some other budget drills. Plus the chargers that come with dewalts, makitas, and the like have protection in them to keep a bad battery from killing them. This firestorm charger is just a transformer with leads, i.e. absolutely no protection.
I hope you can get that charger for free, that would be really great! the chargers that those places sell aren't stock and should have that protection in them
originel is offline   Reply With Quote
Old September 18th, 2004, 04:11 PM     #12 (permalink)
Xtreeme's Avatar
Watch useing dewalt charger and batt. I had a dewalt 14v now for 7 years or so. And bought a second one cause how good they are two years ago. Anyhow they have a IC int eh batt that tells charger if its too hot, if its charging right, if its got bad cell. You name it. This wont like a dumb batt. from a firestorm less they too have IC integrated but I doubt it. Oh by the way Dewalt is Black and Decker just their high end sold under diff name.
R.I.P. TKOP
Xtreeme is offline   Reply With Quote
Old September 18th, 2004, 04:12 PM     #13 (permalink)
JW
Send a message via AIM to JW
Had a simular problem with 2 new 14.4v skil cordless drills.
4 batteries and 2 chargers are shorted out. Less than 1 year old.
Here's a link for the skil
http://store.yahoo.com/boschpowertoo...toteyobos.html
The chargers they sell with the skil drills are cr@p.
Smart charger link.
http://store.yahoo.com/boschpowertoo...oimliofyo.html
JW is offline   Reply With Quote
Old September 19th, 2004, 12:55 PM     #14 (permalink)
Xtreeme's Avatar
I got the cure for all those batt. and charger problems. Buy dewalt. I used to be a contractor and Im telling you-DEWALT rules for long lasting and hard working. Mine 14.4 v one is so old -its the first model they made. Been dropped from step ladder 4-5' to concrete floor, beaten, heated up from continues useage. You name it. Still rocks though. Cant beat that quality..Have one of their saw-zaw's too, same thing unstoppable.
Old September 19th, 2004, 01:29 PM     #15 (permalink)
nuisance since 1968
OuTpaTienT's Avatar
I agree about DeWalt. They are pricey but worth every penny. And yes they will stand up to some incredible abuse and keep right on chugging along.
However my current favorite drill/screwgun is my Craftsman. It too has been taking quite a bit of torture and just keeps on working. It's was originally a 12v drill, and I guess technically it still is a 12v drill, but I've modified it to use an 18v battery pack as well as a 19.2v pack. When I did this I completely expected the motor to burn out within a week or so. That was over a year ago. It gets almost daily use...usually with the 18v batt. Still going strong.
OuTpaTienT is offline   Reply With Quote
Old September 19th, 2004, 01:32 PM     #16 (permalink)
nuisance since 1968
OuTpaTienT's Avatar
Hehe. I just realized what I have done. Never really thought about it before. I've overclocked my drill.
Old September 19th, 2004, 02:07 PM     #17 (permalink)
Xtreeme's Avatar
Hehe, I did that with one co workers 12v dewalt. Put my 14.4v in it. It worked fine. Little warmer than before but not hotter then my 14.4 gets anyways. Just from extra power is all. I looked at the motor in mine, upgraded the chuck to dewalt keyless 1/2 inch instead of 3/8ths. Really a jacob chuck. And the motor in mine and his 12v look the same even. I think up to 18v alot of these co's use the same motor. At 18v however it changes cause I tore a 18v Dewalt apart and it has a larger motor, but gear box is same.
Old September 21st, 2004, 09:41 PM     #18 (permalink)
Rather Large Member
Beemer's Avatar
Send a message via MSN to Beemer
Update:
I used Black & Decker Online Support to get some info.
re: Need Firestorm 14.4V charger, ps180
Hello Gene and thanks for using Black & Decker's on-line support.
If you are experiencing charger failure, your batteries should be tested for the correct voltage. When a charger fails, it could be because one of the batteries has a shorted cell. This can put an excessive load on the charger causing it to fail.
The batteries should be tested at our Vancouver service center:
Black & Decker
1735 Boundary Road
Vancouver, BC
604-291-9942
You can also test a battery by using a digital multimeter. To test the battery, it should be charged on a good Firestorm three-hour charger (do not use any other charger). The battery only needs to be placed on the charger for two minutes (this will not damage the charger if only done for two minutes). After charging for two minutes, its normal voltage should reach (example: 9.6 volt will read 9.6 volt). Batteries that do not reach their potential voltage will have a shorted cell.
A battery that has a shorted cell should not be used.
Along with getting the batteries tested, you may also obtain extra batteries and chargers through that same service center.
Thank you for allowing us the opportunity to serve you. If your question remains unresolved or if you require additional information please update this incident.
Sincerely,
Lynda
Appearently, there can be a dead cell in a battery that will screw up the charger as originel has said.
Cheers!
Beemer is offline   Reply With Quote
Old September 21st, 2004, 10:14 PM     #19 (permalink)
nuisance since 1968
OuTpaTienT's Avatar
Yep. Have you ever opened up one of those battery packs? All they are is bunch of small cells (about the size of a "C" battery or smaller) wired in series. The higher voltage packs simply have more cells in them.
Old September 21st, 2004, 10:25 PM     #20 (permalink)
Rather Large Member
Beemer's Avatar
Never had the chance to open one up. May have the chance soon though. lol
Cheers!
:( stupid rain butch81385 IMO Community 22 September 20th, 2004 12:12 PM
Ipaq 5555 Charging Issue Big Calhoun Mobile Computing 0 October 17th, 2003 01:06 PM
Rechargeable batteries iNeb General Tech Discussion 4 October 15th, 2003 12:49 AM
Battery usage iguana Mobile Computing 3 October 10th, 2003 12:16 AM
18V Cordless Drill $15.95 Richard Cranium IMO Community 1 June 26th, 2002 06:21 PM
Is It Just Me? (1661)
HELP!!! What do you think of this s.. (25)
windows 7 retail and rtm (5)
Review My Build (6)
My 1st pc build (40)
[F@H SPAM 11/1/09]New month . . . n.. (34)
Aero in Vista (7)
slaving laptop drive (7)
[F@H SPAM 11/08/09] Where has all the.. (2)
Which monitor should I get? (13)
nvidia geforce 9500GT 1gig DDR2 (3)
[F@H SPAM 11/1/09]New month . . . new.. (34)
Endless BSOD to Recovery Manager loop.. (0)
HELP!!! What do you think of this sys.. (25)
New Processor, Monitor will not turn .. (3)
Determining ip route and serial addre.. (8)
can u beat freecell # 1941? (11)
Dell 8300 Graphics Problems (1)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
