Results 1 to 2 of 2
    Aug 2003
    Garland, Texas
    160
    how to fix rubber surround on a sub?
    hello people, it has been awhile since my last post here, maily because i needed no help in awhile but now i need some advice. ok i'm not so sure if many people are into audio, home and car, but i'll try anyways. ok this one is about car subwoofers. ok they are MTX Thunder8000, 1000 watts peak, their are 10" 2 of them. and they are not old they are only about 2 months old, and for some undisclosed reason the rubber surrounding on both of them became detached from the outer rim. and when u lift up the rubber surround there is a little lip that they were once attached to, one of the subs it is detached all the way around, and the other most of it. i got these from my friend who only had 400 watts going to them a peice, so we thought it might be his boxes because they are small, because he has a truck, but besides that some one told me i can use silicone epoxy and put it around the lip and let it dry for a few days, and itll be fine. but im not sure ive never seen subs do this before. but i was just wondering if anyone has tryed repairing surrounds on a speaker or has any tips or if there is a place to get them repaired, but basically any pointers or tips or information is helpful thanks. oh yes it is rubber surround not foam.
    <JiGGleS>
    INTEL QX6700 OC'D TO 3.1GHZ, EVGA 780I FTW, 8 GIG KINGSTON HYPERX DDR2, EVGA 8800GTX OC'D, X-FI PLATINUM
    norml.org thekingofpain's Avatar
    SoCal
    5,434
    Do a search for "speaker re-coning" if you insist on not buying new JL's...
    (sounds like someone has their watts rating screwed up or blew it out with a sealed cab---or something?)
  1. I have 5.1 audio, but music is only coming out of 3 speakers.
    By gorath in forum General Tech Discussion
    Last Post: July 3rd, 2004, 12:43 PM
  2. Surround Sound problems!
    By Cpt Cecil in forum Technical Support
    Last Post: September 16th, 2003, 07:49 PM
  3. electrical connection strengthener?
    By daveleau in forum IMO Community
    Last Post: August 8th, 2003, 04:04 AM
  4. Surround Sound doesn't work
    By jmoore2001 in forum PC Hardware
    Last Post: April 24th, 2003, 05:14 PM
  5. HUH ?
    By MegalosSkylaki in forum IMO Community
    Last Post: October 20th, 2002, 12:23 PM
