September 27th, 2004, 04:03 PM
RIP, F-14 tomcat. Best fighter in the world for 33 years
September 27th, 2004, 04:34 PM
Most Macs are easy to open.
I am still trying to figure out how to take out the CD-ROM on my G3 tower.
__________________ "Those who can make you believe absurdities can make you commit atrocities" - Voltaire |
September 27th, 2004, 04:40 PM
| Quote: |
Originally Posted by MTAtech Most Macs are easy to open.
I am still trying to figure out how to take out the CD-ROM on my G3 tower. | I meant the iMac G5 is easier to open then previous generations of the iMac. The jellybean(G3) iMac was easy to open but, so hard to access the parts due to the CRT.The lamp or sunflower(G4) iMac was hard to open and hard to access the guts. The Jay Leno(G5) iMac is easy to open and easy to access the parts. |
September 27th, 2004, 04:42 PM
| | The FNG
I don't see why he's disassembling it.
There goes the warranty.  |
September 27th, 2004, 05:48 PM
If you dissasemble a Mac the warrenty's gone? |
September 27th, 2004, 05:52 PM
September 27th, 2004, 05:55 PM
| Quote: |
Originally Posted by FatalException | You can upgrade the ram and maybe the HD and it won't destroy the warranty. Overclocking the G5 will. |
September 27th, 2004, 06:10 PM
Macworld seems to think differently... http://www.macworld.com/2001/10/bc/howtoimac/
It says upgrading the HDD "may void your warranty." I'm not sure the details - I don't use Macs since I like opening up my PC's without worrying that I'm SOL if something I install doesn't like the rest of my components - I'm simply restating what both this macworld article and the slashdot article say - both of which seem to imply that opening up your imac will void the warranty.
Granted, the MacWorld story is old - but I don't think the new iMac's warranty is any different from the old one... Just beware, early iMac G5 adopters!!! Jobs may not fix your machine if you get too curious with what's inside it...  |
September 27th, 2004, 06:33 PM
| Quote: |
Originally Posted by FatalException Macworld seems to think differently... http://www.macworld.com/2001/10/bc/howtoimac/
Granted, the MacWorld story is old - but I don't think the new iMac's warranty is any different from the old one... Just beware, early iMac G5 adopters!!! Jobs may not fix your machine if you get too curious with what's inside it...  | As I said the HD may void the warranty. But, the ram won't. How do you suppose to upgrade the ram? You have to open it up. So upgrading the ram is a definite no it will not void the warranty. The HD may void it. |
September 27th, 2004, 06:36 PM
| | Onii-san
| Quote: |
Originally Posted by Mr.Macintosh As I said the HD may void the warranty. But, the ram won't. How do you suppose to upgrade the ram? You have to open it up. So upgrading the ram is a definite no it will not void the warranty. The HD may void it. | I thought you had to take it into a certified apple store?
