Join TechIMO for Free!
Currently Active Users: 1519
Discussions: 182,845, Posts: 2,184,658, Members: 225,647
Old September 29th, 2004, 09:21 AM   Digg it!   #1 (permalink)
Shooping list ? need help ne thing you would change ?
-#676 1/2" *BARE RAD* Dual 120mm High Flow Radiator - Swiftech &$59.98
-MCW6002-A AMD K7 CPU Water Block - Swiftech $59.98
-Swiftech MCW50-T GPU Block & 80w Peltier $85
-*UV BLUE* PrimoFlex Tubing 1/2" PER FOOT - OEM $2.98
-Panaflo - 4X120mm 'ULTRA' 115cfm 45.5dba U1A Case Fan $34.98
-NB-1C *COPPER* Chipset Cooler (no fan) - Thermalright $24.98
-OCZ *NEW 8 PACK* BGA *COPPER* Ramsink Pack (4 vid card) $24.98
-CRC-U01 Copper Ram Sink Kit (8 Pieces)- Coolermaster $14.98
-DANGER DEN LANG D-4 12V PUMP W/ MOUNTING BRACKET - $114
-PC3700-EL 2x512MB *EB PLATINUM* DUAL CHANNEL (1024MB KIT) - OCZ $541.36
-Sapphire RADEON™ X800 PRO 256Mb VIVO $595
||Console|| is offline   Reply With Quote
Old September 29th, 2004, 10:28 AM     #2 (permalink)
where's fargo?
bombledmonk's Avatar
Those must not be US prices, those ram and vid card prices are outragious.?
I might recommend getting a Waterblock that can be used on both K7 and K8 in case you want to upgrade in the near future.
Since you asked what I'd change, The 6800GT would be my choice for a card I'm going to overclock. With a full 16 pipes there is more potential gain from a good OC.
bombledmonk is offline   Reply With Quote
Old September 29th, 2004, 12:14 PM     #3 (permalink)
Im from canda thats y the prices are that . The x800 pro im getting will soft mod into a x800 xt pe . I wannta get the best cpu water block i can for my 2400+m I dont care about upgradde when i get a 64 it will be the top of the line wb for that cpu .(just got a raise that y i dont care abou tthe $$ )
also i was thinking about the gainward 6800 but 1 game made the diff for me . cs source liek dubble the fps , cs is my fav game and i know i will like the new 1 . and on ORB all the top slots are x800's not 6800's
Old September 29th, 2004, 05:20 PM     #4 (permalink)
where's fargo?
Then it looks like you're pretty well good to go.
I haven't looked lately but I don't remember any way to softmod an X800pro to XT. Isn't there a different number of pipes 4 of them having been physically cut on the X800pro?
Old September 30th, 2004, 07:18 AM     #5 (permalink)
on a vivo cards the pipes are just disabled like on the 9500's
http://www.ocforums.com/showthread.php?t=312063
thill tells how to do it
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Changing the name of a Directory in 'Documents and Settings'... matius Applications and Operating Systems 3 April 29th, 2004 10:40 PM
Can the font colors on Win XP desktops be changed? used submarine Applications and Operating Systems 1 May 10th, 2003 12:35 PM
The way I’m honoring our men and women in Iraq Terminal23 IMO Community 4 March 22nd, 2003 12:46 AM
Use ICQ? Dont like the bloat? ICQ Lite - Official AuraEdge Applications and Operating Systems 28 October 4th, 2002 07:16 PM
two choices MOBO?? alondra Motherboards 3 September 4th, 2002 04:50 PM
Alaska Gov. Sarah Palin Is McCain's.. (102)
Is It Just Me? (10314)
Finally!! "Male enhancement sn.. (22)
Damn the Constitution, guns should .. (98)
Built a new PC, Getting Boot Failur.. (6)
Samsung T220 22" monitor not w.. (7)
first build. need help. (0)
3DMark06 CHARTS (835)
Budget vid card recommendations (2)
oil change (2)
Official World of Warcraft Thre.. (4023)
Abit VA-10 (0)
Logitech's G25 compatible games.. (5)
search items (0)
GeForce 6800 GT PCI-e fails to .. (2)
FS: IBM t42 laptop, Dell 6000 n.. (1)
Alienware PC (0)
GIGABYTE GA-EP45T-DS3R,& C2.. (0)
