Toolkit
Currently Active Users: 2176
Discussions: 200,919, Posts: 2,379,027, Members: 246,286
Old October 6th, 2004, 05:46 PM   Digg it!   #1 (permalink)
Question
Toolkit
I am looking into buying a tool kit. I live in the uk, what should I look for in terms of what comes with it? What will I need e.g phillips screw drivers and sizes etc
KillCity44 is offline   Reply With Quote
Old October 6th, 2004, 06:25 PM     #2 (permalink)
I'm silently judging you
ArcticFox's Avatar
Send a message via AIM to ArcticFox Send a message via MSN to ArcticFox Send a message via Yahoo to ArcticFox
Why not just build your own with everything you think you'll need?
Like:
A few sizes of Phillips screwdrivers
A torx set if you can find one
A couple flash keys for keeping drivers and whatnot on them
Spare floppy drive, CD drive
www.pcpowercooling.com get their PSU tester
Assorted screws galore
Laptop 2.5" - to IDE adaptor
Little travel mouse
Compact keyboard
Leatherman
Thermal paste
http://www.zip-linq.com/ some of those
A laptop HD in a USB enclosure (for backups and stuff)
Keys to open locked cases (standard for the most part)
A USB WiFi adaptor
Small flashlight, go with a Surefire
A lot of extra jumpers for CD drives and HD's
DVI-to-VGA adaptor
Sharpie
www.highspeedpc.com look for cool stuff there
A bunch of extra standoffs for mounting mobo's in cases
Spare rails for Antec cases
Asprin
Anything else?
ArcticFox is offline   Reply With Quote
Old October 6th, 2004, 06:45 PM     #3 (permalink)
wow, that's alot, ok, I onyl really need it for upgrades and stuff so a flash card would be handy, could do with some thermal paste, all the screw drivers and stuff, got all them, little torch ive got. all the keys to open cases are the same right?
Old October 6th, 2004, 06:51 PM     #4 (permalink)
ArcticFox's Avatar
As for the keys...well, yes and no, just grab as many as you can find and you will probably be set. They aren't "standard" as I stated really, but most of the time they will all work.
Old October 6th, 2004, 06:53 PM     #5 (permalink)
Ok, brilliant, as I get more confident with taking pc's apart ill build up my kit, for now it's basic but some of your ideas would definately help, e.g the paste and flash card.you know inside a pc? if it was unplugged and everything and I opened it up, is there ahigh voltage that can kill because some things that have internal memory hold electricty yea? do computers do that?
Old October 6th, 2004, 06:55 PM     #6 (permalink)
mazdarx7-64's Avatar
YES!! Get a wrist strap to gound yourself to the case, or always touch part of the case while working on the PC.
BSOD.........
The reason why I'll be drunk tonight.
Are you a winner?
mazdarx7-64 is offline   Reply With Quote
Old October 6th, 2004, 06:58 PM     #7 (permalink)
ArcticFox's Avatar
Correction - the grounding strap is to protect the PC, not you. If it was me vs my PC vs an outlet, I'd rather get shocked myself anyways (I've done it, full-wall-socket-power right to the bone) then lose my expensive PC.
Old October 6th, 2004, 06:59 PM     #8 (permalink)
yup, just got a wrist strap with a free anti static mat
Old October 6th, 2004, 07:03 PM     #9 (permalink)
I though kill was refering to killing pc parts, yeh a wrist strap won't do crap for you.
Old October 6th, 2004, 07:07 PM     #10 (permalink)
so could i get killed taking pc's apart considering they are turned off etc...
got visual studio, now what? JacobM5727 Webmastering and Programming 1 November 26th, 2003 06:47 PM
J2ME: Socket should be possible on Nokia....check this: gicio Webmastering and Programming 0 June 5th, 2003 07:07 AM
52x24x52 LITE-ON!!!!SLOW!!!! Webmaster_Trent Storage Related 29 May 28th, 2003 09:21 PM
Windows 2000 Problem--help! Martoch Technical Support 6 September 7th, 2002 02:50 PM
Test your Computer Monitor GoSharks Graphics Cards and Displays 20 April 4th, 2002 01:31 AM
Is It Just Me? (2839)
Obama the Muslim (9)
Foreign voltage (8)
Print spooler problem (10)
Browsers wont load websites (1)
Foreign voltage (8)
Virus Doctor Popup? (0)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
