Results 1 to 15 of 15
    Ultimate Member thePh@r@oh's Avatar
    Jan 2003
    2,309
    connection troubles
    today my internet connection has been acting up. i can try to go to a sie and get an error page but if i refresh it goes right to it. i am connected by a router. i tried to do a dhcp renew but that didnt help?
    Ultimate Member Droppyale's Avatar
    Dec 2002
    1,964
    have you scanned for adware? or spyware?
    Jan 2003
    2,309
    yea cleaned it all out...but the deal is my roomys computer is doing the exact same thing
    Jan 2003
    2,309
    new developement now only IE is screwing up....it appears that mozilla works fine
    edit: nope it appears that just some sites wont work...for instance i can come here but not google. I can go to americas army but not voyeurmods. and thats with IE or MO
    Rather Large Member Beemer's Avatar
    Vernon, BC, Canada
    10,197
    I've noticed that there have been a few sites down in the last couple of days. Try accessing Google. If you can make it there, you should be good to go and the problem lies somewhere outside your control.
    Cheers!
    Vernon, BC, Canada
    10,197
    Many of the sites I had problems with yesterday and last night have come back online. What ever it is, I think the problem is being solved for us.
    Cheers!
    Jan 2003
    2,309
    googles back but its still wiggin out at some other sites
    hopefully this will be resolved shortly
    Jan 2003
    2,309
    this thing is still going nuts what could it be?
    Jan 2003
    2,309
    ok its getting really annoying now at just about every site i try to go to i have to refresh 2 or 3 times before the page finally loads
    Retired mostly.
    Finland
    5,150
    Are you losing packets to your dns server?
    Jan 2003
    2,309
    have no clue.. how would i check that?
    Jan 2003
    2,309
    any ideas...anyone?
    Dec 2002
    1,964
    is the conection going through a router?
    I was having the same problem once, intermitent conection problems, turns out my router was malfunctioning...
    Jan 2003
    2,309
    dont worry about it i found the culprit the cable going into the WAN port was bad...DUH!!!! i always forget to check the easiest stuff first
  15. #15
    Jan 2003
    2,309
    ok i was wrong its still goofing up
    i think its the router? what should i do
    ive reset it and it still does it...what next
  1. 1394 connection? what is that??
    By pineapple in forum Security and Privacy Issues
    Last Post: September 22nd, 2006, 05:20 AM
  2. Win XP + a Scsi setup??
    By whannanna in forum Applications and Operating Systems
    Last Post: October 8th, 2003, 08:17 AM
  3. More engine fun!! :)
    By Whir in forum IMO Community
    Last Post: April 12th, 2003, 01:53 AM
  4. Too many cows?
    By fyxxer32 in forum Distributed Computing
    Last Post: January 16th, 2003, 01:43 PM
  5. New Nvidia Detonator Drivers 28.90
    By hifi in forum Graphics Cards and Displays
    Last Post: May 12th, 2002, 02:07 PM
