usb mouse issue
Currently Active Users: 1603
Discussions: 204,496, Posts: 2,419,327, Members: 249,919
Old October 14th, 2004, 10:37 AM   Digg it!   #1 (permalink)
TODComp's Avatar
Send a message via AIM to TODComp
usb mouse issue
hmm....whenever I start my computer up my usb optical IBM mouse just plain doesn't work. If I unplug it and plug it back in, it works. Sometimes I'll need to do it couple times. I figured this was the mouse because I had dropped it a while back and it messed up the side button, but a friend of mine just told me he had the same problem....differnt mouse, different hardware. Running XP pro SP2.
Any ideas? I've tried re-installing my usb drivers....oh also, my other usb devices don't have any problem.
TODComp is offline   Reply With Quote
Old October 14th, 2004, 10:41 AM     #2 (permalink)
SP2
I HATE IT. Did it work before you installed sp2?
You could also get one of those adapter things and convert the usb to the older mouse port.
gt1rs is offline   Reply With Quote
Old October 14th, 2004, 10:55 AM     #3 (permalink)
TODComp's Avatar
I beileve it was doing this with SP1 as well
Old October 14th, 2004, 07:44 PM     #4 (permalink)
skuz's Avatar
I've seen this problem before, you can try disabling the USB power off feature in your hardware manager. Right click on every USB hub and go to power option or power management (sorry my OS isn't english) and uncheck "allow this device to be powered off"
skuz is offline   Reply With Quote
Keyboard Problems... PLEASE HELP! MsCIS Technical Support 14 July 11th, 2004 03:37 PM
Why sounds like device connecting and disconnecting keep comming up? psjohny Applications and Operating Systems 10 January 20th, 2004 06:47 PM
Knoxpix and errors-need a little help here. ChrisK2972 Linux and Unix 4 August 5th, 2003 01:01 PM
Keyboard doesn't work in linux install? iNeb Linux and Unix 8 April 11th, 2003 08:19 PM
Frozen Windows Xp ocit Applications and Operating Systems 4 November 25th, 2001 11:14 PM
Is It Just Me? (1575)
CBO: Obama's health care plan cuts .. (93)
USB not recognised..... (16)
Do you use "self check-out&quo.. (8)
would this build be enough for WOW? (14)
Recent Problem (15)
Need some suggestions on building a.. (26)
Motherboard the culprit? (6)
[ F@H Chat] 03/07/10 New Month New.. (89)
Suggestions? (6)
Can't Rename Files (11)
Hard drive full = slower computer? .. (6)
Want a new power supply for my Dell.. (35)
Windows XP Pro Error log (8)
[ F@H Chat] 03/07/10 New Month New T.. (89)
Need some suggestions on building a g.. (26)
burner not burning. (3)
YOUR BEST TRICK OR TIP FOR YOUR COMPU.. (20)
HTML (2)
Hard drive full = slower computer? Is.. (6)
Reading Raw data off an SD (MMC) card (8)
Recent Problem (15)
Can i upgrade my gateway nv5448u grap.. (1)
Drive 0 not found: Serial ATA, Sata-0 (9)
i need to find my DNS server IP addre.. (21)
HP Pavillion Laptop ze4220 won't turn.. (15)
Lexmark Printer Prestige pro805 (0)
E:\Pictures is not accessible. the d.. (4)
Replacement hard drive for Dell 600M (18)
toshiba l300-20d upgrade (0)
AE's Windows Troubleshooting Guide (24)
Audio skips when I play a cd or dvd o.. (0)
Want a new power supply for my Dell. (35)
Selling Xbox Live 1 month codes!!! [$.. (1)
Suggestions? (6)
