Building a new PC...need some advice!
Currently Active Users: 2323
Discussions: 200,944, Posts: 2,379,340, Members: 246,306
Old October 17th, 2004, 06:22 AM   Digg it!   #1 (permalink)
Smile
Hi dudes...I'm new to the forum and I need some advice...I plan on building my first PC soon, and before buying anything, I'd like to have some opinions from people that know better than me...
So this is what I'm planning to buy...
Antec 1040BII
Athlon XP 2600+ 333FSB
Asus A78NX-E Deluxe
2x256Mb Corsair PC3200 RAM
ATI Raedon 9800PRO ( )
I plan on overclocking the 2600+ to around 3200+ if possible, I'm looking for a good, not so expensive, and quite quiet HSF...I need some opinons on this...I'm on a budget so I can't really spend that much...
I'm still not so sure about the Video Card, I'd like to get a cheaper one but that still would perform quite well...I also plan on o/c.
Any recommendations...
Chaos in 1983! is offline   Reply With Quote
Old October 17th, 2004, 07:03 AM     #2 (permalink)
where's fargo?
bombledmonk's Avatar
I'd recommend getting this CPU instead. It runs a lot cooler and has the ability to OC higher if you want to.
AMD Mobile Athlon XP 2500+, 266 FSB, 512K Cache, 45 Watt - OEM
http://www.newegg.com/app/ViewProduc...103-401&depa=1
For a simple bump to 3200+ speeds this will be more than adequate.
Speeze "FalconRock" CPU Cooler for Socket A/ 370, Model "5F286B" -RETAIL
http://www.newegg.com/app/ViewProduc...150-023&depa=1
Beyond that you will probably want to try and find a Thermalright SLK-900A/U heatsink if you want to overclock more. I'm sure some other people will be able to add more good coolers.
bombledmonk is offline   Reply With Quote
Old October 17th, 2004, 07:12 AM     #3 (permalink)
DallasDon's Avatar
I agree with Bomble on the processor and Speeze heatsink, only I would get the all copper on for about the same price.
For a motherboard, look at the ABIT NF-7. Not the -M, or the -S (if you don't need Sata), or the S2 version.
The lower wattage and unlocked mutlplier make is a cool running overclocker.
Here is a recent one I built, currently running @2.2 Ghz, 100@ CPU usage. Temps stay below 50C.
DallasDon is offline   Reply With Quote
Old October 17th, 2004, 06:19 PM     #4 (permalink)
Thanks guys...
I made a small search on newegg for low dba and quite cheap ones as well...this is what I came up with...
Cooler Master XDream II (CFM= 31.4 - 62.8, dBA= 24)
http://www.newegg.com/app/ViewProduc...103-146&depa=0
SPEEZE CPU Cooler (CFM= 37.87, dBA= 26.5)
http://www.newegg.com/app/ViewProduc...150-040&depa=0
Spire WhisperRock IV (CFM= 28, dBA=21.1)
http://www.newegg.com/app/ViewProduc...151-111&depa=0
Thermaltake "Volcano 7+" (CFM=49, dBA= 24/35/47)
http://www.newegg.com/app/ViewProduc...106-014&depa=0
What do you think about these HSF??? are they good and quiet?...Also I've been told to get the Thermaltake EXTREME VOLCANO 12, but it is a lot more expensive than the ones posted before, and also I hear TT fans are quite loud...do you think I would really need all this power for what I intend to do??
As of the Motherboard...I looked into the Abit mobos Don suggested, but I couldn't find the NF-7, these were the ones I was able to find...
ABIT "NF7-S2"
http://www.newegg.com/app/ViewProduc...127-185&depa=0
ABIT "NF7-S V2"
http://www.newegg.com/app/ViewProduc...127-166&depa=0
I get Free shipping on both, the S V2 version is a bit more expensive but I am willing to pay those for the onboard nVIDIA SoundStorm APU(Dolby 5.1) + 6-Channel AC97 CODEC 5.1 support...
Are both of these as easy to overclock as the NF-7
Looking at dons pic and comparing it to the NF7-S V2...they look exactly the same, are they the same board?
Thanks again for all your help
Old October 17th, 2004, 06:59 PM     #5 (permalink)
where's fargo?
They are basically the same board, just a newer revision and a new name to make it sound better. somehow?
Old October 17th, 2004, 08:11 PM     #6 (permalink)
Oh I see...so I think I'll go with the Abit NF7-S V2...$69 bucks after mail in rebate...
What about the fans...are those any good?
Thanks again
Old October 17th, 2004, 08:19 PM     #7 (permalink)
mazdarx7-64's Avatar
No links? I would go with the all copper HSF you had listed above.
BSOD.........
The reason why I'll be drunk tonight.
Are you a winner?
mazdarx7-64 is offline   Reply With Quote
Old October 17th, 2004, 08:20 PM     #8 (permalink)
BustedAvi's Avatar
I have the nf7 s and its fine for overclocking with the 2500, got mien running at 2.2 ghz temps around 50. I bought the nf7s for the soundstorm, you'll love it i garantee.
CANADA KICKS ASS!
BustedAvi is offline   Reply With Quote
Old October 17th, 2004, 08:52 PM     #9 (permalink)
Here are the links...I had already posted them above
Old October 17th, 2004, 10:05 PM     #10 (permalink)
xcheck2430's Avatar
Send a message via AIM to xcheck2430
ram
dont go with the 2x256. at least go with 1x512 so u can upgrade later. but if u really want it for gaming, get a gig, its really a serious difference. i've used 256 and 512 on old comps, and the difference there isnt too much, but between 512 and 1 gig, it really makes everything run much faster...especially unreal 2k4
xcheck2430 is offline   Reply With Quote
Best harddrive brand to buy? dlh75 Storage Related 37 December 23rd, 2005 02:16 AM
Motherboard for new builder THICK Motherboards 12 May 31st, 2003 05:41 PM
How much? brandon184 General Tech Discussion 37 January 1st, 2002 06:21 PM
IT WORKS!!!!!!! draboo General Tech Discussion 25 December 8th, 2001 09:33 PM
hercules/visiontek graphics card advice nerdgirl Graphics Cards and Displays 4 December 6th, 2001 02:18 PM
Making Health Care Worse (162)
The disrespect of Obama by Russian .. (16)
Is It Just Me? (2918)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
How to convert MP3's (0)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
