Thread: how do I flash my bios...
October 18th, 2004, 12:34 AM #1
I have an ECS motherboard and an american megatrends bios. This is all according to www.pcpitstop.com by the way. So how do I flash it to the latest update?
The Master of Puppets
October 18th, 2004, 12:35 AM #2
What issues are you trying to correct?
Also, download Everest Home Edition for a hardware analysis to ensure you are trying to update the bios for the correct board. Does your board have any letters/numbers on it that can help identify it correctly?
October 18th, 2004, 12:38 AM #3
None that I know of. I am just wondering if I get the latest update if I will be able to change more settings, right now it wont let adjust any settings at all. Like clock frequency, lowering the multiplyer, vcore. Just want to see if it gives me the option to overclock my 1700+ palomino a bit lol. Yeah its old, my new mobo/cpu will be here tomorrow heh.
Everesthome says its a totally different motherboard lol. It says its a PC chips M830LR...The Master of Puppets
October 18th, 2004, 12:45 AM #4
you will not find overclocking or unlocking bios updates at the manufacturers website... you can sometimes find "Rogue" updates outside of the manufacturers offerings...
everest is most likely right and can be verified by looking on the board physically...
go to ECS's site, they have good directions and any flashing utilities you may need...
beyond that you will have to do some searching to find a suitable oveclocking Bios...
Use these at your own risk as they are often not as reliable as from the manufacturerLast edited by JPMiller; October 18th, 2004 at 12:48 AM.
October 18th, 2004, 12:49 AM #5
How do I find them heh.
EDIT: ok JP. Pcpitstop said it was an ECS and everest home said it was a PC Chips.The Master of Puppets
October 18th, 2004, 01:00 AM #6
Whats the model number of your ECS motherboard?
October 18th, 2004, 01:07 AM #7
I am fairly sure its a PC Chips mobo now. Thats what Everest Home says.
This is the model number everest gives me.
Motherboard ID 62-0429-001131-00101111-040201-SiS735$M830LR_Release 04/29/2002 SThe Master of Puppets
October 18th, 2004, 01:11 AM #8
When you first turn your computer on and you come up to the first boot screen what are your letters and number in the bottom left hand side this sometimes will give the mobo model number and yes ECS could be a pchips board.
October 18th, 2004, 01:19 AM #9
Theyre basically the same company... PCPitstop just grabs generic info and EverestHome usually gets more correct info..
October 18th, 2004, 01:19 AM #10
Thats the only way to get the model number? Read the numbers and letters as the flash by during start up lol?
October 18th, 2004, 01:28 AM #11
Try this thread ... I now remember that this is the same as the K7S5A... it is the PcChips version of the infamous ECS K7S5A.
You may also find this site to be informative in getting the most out of that board...
http://www.ocworkbench.com/2002/ecs/k7s5aguide/Last edited by JPMiller; October 18th, 2004 at 01:30 AM.
October 18th, 2004, 01:28 AM #12
what thread heh?
October 18th, 2004, 02:36 AM #13
Ok apprently the board is a m830LR and K7s5a by ECS. I can update the bios from the files on ecsusa.com . Problem is there are 2 listed versions of the mobo, the k7s5a pro and one called k7s5a + PCB 1.0x.... I am not sure which of the mobo's mine is heh, it only says K7s5a...
October 18th, 2004, 02:50 AM #14
you need to physically examine the board for the revision no#
if you want to up the FSB you have to use the oveclocking Bios I linked to.
You will need to do a little research and I suggest the Chipset HSF upgrade because those chips run hot and the heatsink doesnt even physically touch the northbridge..
October 18th, 2004, 02:51 AM #15
thanks again JP, I sent u some emails on other things heh, if ya didnt see um.
October 18th, 2004, 03:06 AM #16
Ok the only prob is the mobo is listed as a PC Chips mobo. I know its the same as one of the ECS k7s5a. I just cant tell which because its not listed as an ECS. I see this revision # by the AGP slot buts it not the same as any of the ECS numbers, its a PC chips #.
October 18th, 2004, 03:07 AM #17
Those were good questions that should be shared so others wanting that info can benefit as well...
Yes Sata drives are different... most as far as I know are still jumpered to be slave, master, or cable select, but the setup is quite different... you have usually two or more, one drive connectors on the Motherboard... you need a SATA cable that only plugs in one way...Is installing a sata hard drive any harder then an IDE? I just hook it up to my mobo and connect it to the power supply and configure it to boot in bios right? I am getting some inferences from techimo forums that sata is different in that you don't set them up to be primary and slave like IDE.
you may need a special PSU connector depending on the drive you purchased, some come with a standard 4 pin Molex and some with a special SATA connector.
If your attaching it as a main drive to be used for the OS, then you boot from the windows CD as you would normally but when it is loading the basic files at the beginning, it will scroll the option of pressing F6 to load SCSI drivers, that is when you need the Sata drivers on a floppy for installation... In your bios the Sata drives are actually recognized as SCSI drives...
Once your ready to start you can come back for more info...
This sounds more like video drivers or a video card restriction than a Monitor problem... upgrading the drivers or the card itself would be the most likely option...I have had the same CRT monitor for the longest time. Since 99 when I got my first computer. And for the longest time I thought it was a bad monitor since it didn't go any higher then a 1024x768 resolution in the my properties menu. I ran that PCpitstop program you recommended and it gave me all checkered flags because except for one yellow minor flag for not enough ram. But I read everything in the results and found out that it tested my monitor. It said my monitor's max resolution is 1600x1200. My computer wont let me slide the resolution that high. Any ideas?Last edited by JPMiller; October 18th, 2004 at 03:21 AM.
October 18th, 2004, 03:21 AM #18
Well pcpitstop said it was 1600x1200, but now everest home is actually saying it is 1024x768 lol.
October 18th, 2004, 03:25 AM #19
PcPitstop is only generally correct, usually EverestHome is more accurate...
Is everest reporting the current resolution?, or the max possible for that monitor... what exact model no# is on the sticker on the back?
October 18th, 2004, 03:30 AM #20
Everest says that is the max reso. Lemme look for the #.... seems like I am lookin for lots of numbers with everything today lol...
Bios/Mobo can't be updated.
By ZeroAce in forum Technical SupportReplies: 10Last Post: April 16th, 2004, 08:37 PM -
Major Problems
By d1sc g0lf3r in forum MotherboardsReplies: 4Last Post: April 4th, 2003, 10:48 AM -
PC Chips M810LMR - XP Proc possibility
By aznlurkerz in forum MotherboardsReplies: 5Last Post: February 11th, 2003, 10:00 AM -
ASUS kicking my butt!!!! BIOS Help Please!
By RADAR1797 in forum MotherboardsReplies: 13Last Post: January 20th, 2003, 10:24 AM -
Saving a copy of old bios but not flash to new?
By Bovon in forum MotherboardsReplies: 7Last Post: February 3rd, 2002, 02:04 PM
Much of what you say about corporate behavior and its effect is true, although it appears to arise out of a misreading of my own statements.Let me address the part that is not: If untaxed profits...
Senate Report on Apple Tax Dodging
