Page 1 of 2 1 2 LastLast
Results 1 to 20 of 38
    Jun 2002
    202
    Software Audio Amplifier for a laptop ? Speakers not loud enough... HELP !
    Okay I have a problem with my laptop when watching a movie or dvd it isnt loud enough. I have all audio options maxed out. I know winamp has audio amplifier built in, is there any software programs that amp all audio output ? I know my speakers can output more but its based on input.. ie a small sound played on the laptop comes out small.. if you reflect it as loud(or record it as loud) it comes out loud. So... Anyone got any options.. ? Software costs are not an option.. (wink wink) Hardware is not an option.
    Member CMP 2003's Avatar
    Dec 2003
    South FL
    164
    Its probably your speakers, they can only handle so much...they are probably a pretty low wattage, hence the lack of great sound.
    AMD A64 3200+ (Venice)@2.2
    MSI K8N Neo2 Plat.
    Corsair 1GB ddr400 @ 2-3-3-8
    eVGA 6800 128mb AGP
    WD 80 gb IDE
    MGE 500w PSU
    MGE Titanium ATX Case
    Jun 2002
    202
    Yes I know they arent all that great.. but.. playing music recorded at high volumes results in high volume music.. I know the speaker can output more because on songs they do.. on dvd's they dont.. I know someone out there has made a software AMP (akin to winamps amp..) that allows you to amp the level of sound so its put out louder on your speakers..
    Ultimate Member rabidaardvark's Avatar
    Jul 2004
    right here
    2,443
    Even pushing the speakers beyond their capability may not be the best option. I mean the quality is going to degrade. Why are external speakers or headphones out of the question? They make speakers that are a few mm's thick and headphones with built-in preamps.
    size=1 rocks
    Oct 2008
    u can try
    Quote Originally Posted by Mithin View Post
    hi,
    u can try with SX Fidelity Amplifier it seems good
    beeyar
    Oct 2008
    14
    Hopefully the original poster got their problem solved, seeing as it was over 4 years ago...
    Nov 2008
    Smile Need Volume Amp for Laptop
    Thanks for the post anyway. It is 4 years later and now I have the same problem as the original poster.
    Jan 2009
    Smile VLC
    Download VLC and use the +20db equalizer. Problem solved.
    Mar 2009
    vlc
    wats vlc?
    Mar 2009
    Cool VLC
    VLC is a media player that can basically play any kind of audio or video format.
    It's a must for every single PC user in the world - seriously unmissable. Here's the link
    VLC media player - Overview
    Feb 2007
    Springfield
    13,484
    5
    *cough* thread is from 5 years ago *cough*
    FAQ's ~ Team Stats
    My PC
    Minnesota
    17,364
    LOL, I went to post a reply the other night when they posted "whats VLC" and after several tries, kept timing out on the submitting of the reply, gave up, figured screw it...
    but as mentioned its a bit old...
    sho
    sho is offline
    Apr 2009
    2
    Media Player Classic - Combined Community Codec Pack
    Use MPC which is included within the Combined Community Codec Pack
    If you go into Play -> Audio -> Options... then slide the boost bar all the way to the right, your audio playback will have become greatly amplified. Enjoy
    Jun 2009
    2
    Exclamation VLC
    I had the same probleme when watching .avi movies on my laptop and vlc is perfect , it can boost the volume up to 200%
  15. #15
    Jun 2009
    2
    It's might be old but had the same probleme couple days ago!
  16. #16
    oBeY SiliconJon's Avatar
    Feb 2003
    Bethalto, IL
    10,646
    3
    I'm looking for a similar overlay. A driver update lowered the volume but I like the performance of the new driver so I seek a way to further amplify my output on my sound device through a software override. Seek I must.
  17. #17
    Ultimate Member Black*Dragon's Avatar
    Mar 2009
    Occoquan Virginia
    1,319
    Quote Originally Posted by SiliconJon View Post
    Only so much you can get from the hardware. VLC pretty much is giving you the software max. If the pre-amp of a unit is 5watts then all you will get is 5watts.
    Obama Lies
    Grandma Dies
  18. #18
    Feb 2003
    Bethalto, IL
    10,646
    3
    Maybe if I plug it in upside down.
  19. #19
    Feb 2007
    Springfield
    13,484
    5
    I've never seen or heard of a "software" fix for what your wanting SJ. Have you checked into headphone amps?
    I know they can be found for a decent price, and do exactly what your wanting to do. The only downside is you'd have to carry a small amp around with your lappy, which I'm sure is probably what your trying to avoid.
    But if your not totally opposed to the thought of having an external amp, you might check into the Mini 3 line.
    FAQ's ~ Team Stats
    My PC
  20. #20
    Mar 2010
    vlc is a decent software amplifier
    I use Vlc and it really does amplify my audio in my notebooks and netbooks. Hey and its free until MS buys em out.
  1. No sound, K7S5A Pro
    By jerrygarcia in forum General Tech Discussion
    Last Post: October 8th, 2003, 10:29 AM
  2. Distortion #2: NetMD vs. SBLive
    By MD1032 in forum Multimedia and Audio
    Last Post: May 21st, 2003, 09:19 PM
  3. need help finding a site
    By blackwatch in forum IMO Community
    Last Post: May 3rd, 2003, 06:38 AM
  4. sager 5660 - radeon 9k
    By Avicus in forum Mobile Computing
    Last Post: October 22nd, 2002, 12:14 PM
  5. Dumb Question re: Audio Cables
    By Thud in forum Multimedia and Audio
    Last Post: September 20th, 2002, 07:28 AM
