Page 11 of 11 FirstFirst ... 7 8 9 10 11
Results 201 to 206 of 206
  1. #201
    Mar 2011
    CMOS Admin Password Re-Set
    Quote Originally Posted by jose3957 View Post
    hi maybe you guys can help with a problem with my compaq nc6000. Recently i got it a new AC Adapter because i noticed the battery wasnt chraging. however getting the AC adapter i also noticed that my battery aswell was not working so i got a new one aswell. When i turned it on it just stayed in the Hp page didnt let me log in. It told me the press R10=ROM base setup. it dosent let me do anything else i cant login im not sure why
    All you have to do is remove the keyboard, battery, disconnect AC, remove the red/black lead from the Mobo (next to the RAM). You'll see it when you lift up the keyboard. Wait a few minutes (I waited ~15 minutes). Plug in AC boot up. It'll start with memory count up then give you the choice to go to F10. Go in re-set the passwords, save BIOS. You are good to go put it all back together - the cmos password is gone -that should do it nothing else is needed...
  2. #202
    Power up problem with hp compaq nc6000
    Using an old nc6000 for writing. Would not charge the battery. Looked at all the expensive solutions then tried most obvious one - the power cable being worn out. Replaced it at a cost of under $10. Problem solved. No motherboard replacement, no battery replacement. Things are working just fine.
  3. #203
    Feb 2012
    Compaq nc6000 abrupt shutdown problem
    Pls i need to know exactly where those components are located on the board and possibly how to go about opening the system nc6000.My system has exactly the same problem;it starts with no indicator lights on and the CPU fan will be blowing.Sometimes,when it starts, it stays for about 20mins and it will go blank with the fan blowing too and the green lights on.Enlighten me more about this problem.
    Thank you.
  4. #204
    hp nc6000
    guys my hp nc6000 is going at halt state again and again...when i m using 8 ball pool on facebook...fan speed is increases and it goes held...could any body solve my problem???
  5. #205
    Thumbs up NC6000 abruptly turning off, Or orange light
    I have read all your posts and my son has a NC6000 and his started doing this as well. I am an electronics tech so this stumped me thats how I stumbled across this posting. I tried everything suggested and nothing would completely resolve it this issue would return. SO here is what I did to fix this issue.
    Dis-assemble your NC6000 remove the fan and the gold pad the fan sits on on the motherboard is dirty along with the connection side that the fan sits on the motherboard. Take a #2 pencil and use the eraser and clean both of these. If you so desire remove the power board and clean all these as well. Re-assemble and tighten screws accordingly. You will no longer experience this issue. If you do follow the steps all over and clean a little better. The issues resides with the continuity between the fan and the board the circuit is being broken and thats why this issue is there.
    Once you accomplish this you will actually see an improvment in the overall funcionality of the unit. I have bumped it around shook it and it still powers on every single time and will run until I turn it off.
  6. #206
    Oct 2015
    CANNOT ERASE WINDOWS REQUIRING A USER NAME & PASSWORD
    Hello, Im here for you all's expertise! I have a compaq nc6000 & I forgot the user name & password to login to Windows *(when computer is first turned on). Ive read many post in this thread & so far Ive cleared bios, took the battery pack & the cmos (other post call it t...something) battery out for 24hrs, took out hard drive, put in just the power cord & nothing. No matter what I do windows is still asking for a user name & password. Help plzzz!
There are currently 3 users browsing this thread. (0 members and 3 guests)
  1. S Cable - Connecting laptop to tv monitor
    By coopersveronica in forum General Tech Discussion
    Last Post: January 7th, 2010, 06:55 PM
  2. ...compaqs, hps, gateways, etc
    By engineuity in forum General Tech Discussion
    Last Post: May 6th, 2004, 11:14 PM
  3. Compaq power supplies
    By Cyberlore in forum Technical Support
    Last Post: April 26th, 2003, 10:14 PM
  4. Laptops...cheap AND powerful??? Possible?
    By Tekk in forum General Tech Discussion
    Last Post: November 28th, 2001, 06:58 AM
