Using a laptop monitor as a normal monitor???????
Currently Active Users: 2432
Discussions: 200,942, Posts: 2,379,323, Members: 246,305
Old February 12th, 2002, 09:36 PM   Digg it!   #1 (permalink)
Send a message via AIM to br0t
Is there anyway I can hook up my old laptop monitor to my computer and just use it as a monitor?
So i could use just the monitor of the laptop as normal monitor!
is that possible?
br0t is offline   Reply With Quote
Old February 13th, 2002, 02:34 AM     #2 (permalink)
MMock's Avatar
i never seen a laptop with a video out! Look and see if there is one or tell me what brand it is and I will look it up for you and tell you whether or not you can do it!
MMock is offline   Reply With Quote
Old February 13th, 2002, 02:48 AM     #3 (permalink)
Richard Cranium's Avatar
Doubtful as the connections on the lappy lcd screen are specific to the mfg of the unit.
Often even among the same brand the connection will be different.(AFAIK)
These are not your standard 9 pin connection.
Richard Cranium is offline   Reply With Quote
Old February 13th, 2002, 02:50 AM     #4 (permalink)
MMock's Avatar
yeah i wasnt sure if there was the technology yet! I know you can buy a docking station for the laptop though! might want to consider that!
Old February 13th, 2002, 09:17 AM     #5 (permalink)
cadetstimp's Avatar
It's possible but would be very custom and involve soldering.
It would be best just to consider a laptop as an output device only. The laptop will output its signal/image to an external monitor or TV for some, but it will not accept a signal.
If you've every replaced RAM on a few laptops by removing the keyboard on top (depends on the brand) you may have noticed a flat yellow and traslecent ribbon that runs between the flat panel and the base. That is what connects the on board video to the screen and most are a digital connection (not analog like a CRT monitor connecting to desktop PC)
cadetstimp is offline   Reply With Quote
Old February 13th, 2002, 11:29 AM     #6 (permalink)
We have a couple units that do accept video input, but they tend to be very expensive. I haven't seen normal software for this purpose, but terminal services or Citrix might work for some similar purposes without any connections other than network. As far as using just the screen for a monitor, be prepared for a lot of homework in EE and design.
Xaotic is offline   Reply With Quote
Old February 13th, 2002, 03:16 PM     #7 (permalink)
Emc2's Avatar
Send a message via AIM to Emc2
I thought I heard a little bird say a while back that they had PCMCIA card for that?
Emc2 is offline   Reply With Quote
Old February 13th, 2002, 04:54 PM     #8 (permalink)
Ok, thanks everyone, I guess I can't do it with my older laptop.
The disrespect of Obama by Russian .. (14)
Making Health Care Worse (155)
Is It Just Me? (2918)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
