Help me pick my 64bit christmas present!  | | |
November 25th, 2004, 08:51 PM
| | Onii-san
Well, over thanksgiving dinner tonight, I talked to all of my family members about what I want for christmas. I told them I just want 2 things, and that they can all pitch in together so it won't be to expensive for just one person. My present of choice is of course a 64bit CPU and mobo.
So, my current pick is an AMD 3000+ 939 chip with a Soltek mobo. Is soltek any good? It got 5/5 stars on newegg.
Does anyone else recommend a cheaper solution? I want a 939, as a 754 3000+ is only $1 less than the 939 version.
You can recommend any other online stores along as its good as newegg.
Thanks,
-Biz
November 25th, 2004, 08:55 PM
I've seen some really nice reviews on the Soltek mobos, and they seem very nice looking in the photos as well. The SL-K8TPro-939 needs a BIOS flash to be able to support dual-channel RAM at 400MHz, just to let you know.
The A64 3000+ S939 is a beast at overclocking, the average is about 2.5GHz, that's about a 700MHz overclock!
I'm also highly considering upgrading to this setup from my XP 2400+.
AMD Athlon XP 2400+
512MB PC2700 DDR RAM
120GB 7200RPM Hard Drive
GeForce 6600GT 128MB
November 25th, 2004, 08:58 PM
| | Onii-san
November 25th, 2004, 09:01 PM
| Quote: |
Originally Posted by Bizkitkid2001 | That's the one!
And no, PC2700 is way too slow for this chip.
PC4000 if you're going to do some serious overclocking (2.2GHz+)
Use PC3200 for the absolute least, but even then I'd recomend better RAM. http://www.newegg.com/app/ViewProduc...156-012&depa=1
I recommend that if you're going to go with PC4000.
November 25th, 2004, 10:19 PM
| | Onii-san
Damn. That means I need to ask for memory as well. I don't think my family can fork out that much money
And I can't ask for money as if I get money for christmas, my parents get it because I ow them $809 for car repairs.
Also, whats a good heatsink for a 939 chip? |
November 25th, 2004, 10:55 PM
I have the 754 3000+, with the DFI LanParty UT motherboard, it's supposed to be the best overclocking board for 754. You might just be able to hit similar speeds as to the 939...
Pick up some OCZ PC-3200 platinum rev. 2, and you can hit DDR600  |
November 25th, 2004, 11:23 PM
| Quote: |
Originally Posted by MadMan2k I have the 754 3000+, with the DFI LanParty UT motherboard, it's supposed to be the best overclocking board for 754. You might just be able to hit similar speeds as to the 939...
Pick up some OCZ PC-3200 platinum rev. 2, and you can hit DDR600  | Someone I know that I talked to on these boards says that he can't overclock his 3000+ S754 that much at all.
BTW, lots of people choose the Thermaltake Venus 12 for that 64 3000+ and they say it's a great combonation.
November 26th, 2004, 03:34 AM
| | Onii-san
Would I need to reinstall windows if I replace the mobo? Or will it be able to install all the drivers correctly through the normal hardware detection? |
November 26th, 2004, 03:41 AM
| | The Macedonian Member
You would have to just do a repair, instead of a whole reinstallation of windows. |
November 26th, 2004, 03:46 AM
| | Onii-san
I don't even want to do a repair as I will have to reinstall all of my programs  |
