should i give this motherboard another chance?
Currently Active Users: 2108
Discussions: 200,948, Posts: 2,379,414, Members: 246,310
Old December 16th, 2004, 11:15 PM   Digg it!   #1 (permalink)
capybara's Avatar
the board is a gigabyte ga7-dx
it has a xp2000 cpu in it
and a generic stick of 256 MB ddr266 ram.
it worked fine.
suddenly the system died.
i took it all apart, and between a pin of the ram and the notch in the pins was a carbon spot. dead ram!!!
so heres the question
should i try another $30 stick of ram in the board,
or is that a stupid idea, cause the board is bad and likely to fry the new ram?
should i give the board another chance?
or is it a ram killer?
my signature was so lame i deleted it.
capybara is offline   Reply With Quote
Old December 17th, 2004, 08:13 AM     #2 (permalink)
Banned
pphalan's Avatar
I would try to save it naturally remove old ram and use the other socket for the new ram, make sure you check the old socket carefully for shorted pins,clean the carbon off
pphalan is offline   Reply With Quote
Old December 17th, 2004, 12:16 PM     #3 (permalink)
capybara's Avatar
but dont you have to always fill dim slot 1 before using another slot?
Old December 17th, 2004, 12:35 PM     #4 (permalink)
platdragon's Avatar
The only time I see were you must have RAM in a set slot is in dual channel and in some servers avd other machines like printers and such. One of the truble shooting steps to check if the memory is bad or the MoBO is is by changing slots.
platdragon is offline   Reply With Quote
V8PC Logo help needed BITM@D Graphic Design and Digital Photography 309 May 6th, 2004 10:18 AM
BIOS flashing how to? Dark_Smoke Motherboards 5 September 24th, 2003 01:35 AM
blonde convention speaker SHINES draboo IMO Community 10 July 4th, 2003 01:30 PM
Empty Nest Sweet IMO Community 10 June 10th, 2003 10:02 PM
Dear MyEmail... Martoch IMO Community 2 July 19th, 2002 06:14 PM
Making Health Care Worse (175)
Is It Just Me? (2940)
Regular Build (6)
Print spooler problem (15)
Multiple Restarts Required at Boot (1)
Point and Shoot Camera Suggestions. (3)
How to convert MP3's (4)
Graphics Card Upgrade Question (3)
Internet Lost (1)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
