Problems d/l torrents using Azureus
Currently Active Users: 1162
Discussions: 200,929, Posts: 2,379,148, Members: 246,296
Old December 20th, 2004, 10:15 PM   Digg it!   #1 (permalink)
Send a message via AIM to s2cmpugh
Well I updated Azureus like it asked me too, and now I have this error that says "Likely network disconnect/reconnect: Repairing 1 selector, 8 keys.
If you get this message repeatedly, and you are sure there is nothing wrong with your
network setup, and you are running java 1.4 series, then you have likely encountered
a JRE bug, and should upgrade to the newer java 1.5 (5.0) series."
So i went into control panel and updated java as much as I could. It still does it. Any ideas on this?? This is a reptitive error, and my d/l u/l speeds are not as fast as before. My internet connection seems fine too.
Suggestions???
Cris
s2cmpugh is offline   Reply With Quote
BitTorrent questions hulkMAD Networking and Internet 9 January 4th, 2005 07:55 PM
best BitTorrent software vikeor Applications and Operating Systems 34 November 14th, 2004 11:23 PM
what music program? asma1234 General Tech Discussion 20 September 7th, 2004 06:08 PM
Peer 2 peer Himroth Multimedia and Audio 14 June 27th, 2004 12:12 PM
BitTorrent 3.4.1 DanGrease Applications and Operating Systems 18 March 29th, 2004 11:57 AM
Is It Just Me? (2868)
Obama the Muslim (14)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
