Hard Drive Format  | | |
December 21st, 2004, 06:34 PM
How do I format a new Hard drive. I have a third drive that is not recognizid in bios, but it is not formatted. How do I do this? I have it connected to the PCI IDE card and the last connector io the hard drive. I t still does not show in bios. |
December 21st, 2004, 06:42 PM
If it does not show in the BIOS you can't format it. Try changing your jumpper settings on the drive to get it to show up.
BSOD.........
The reason why I'll be drunk tonight. Are you a winner? |
December 21st, 2004, 06:54 PM
When you go into my computer, does it show up in the Hard Drive Section? if it does, and it is not your main OS Hard drive you can right click it and go: Format......Full Format.
"There is no reason anyone in the right state of mind will want a computer in their home."
- Ken Olson, President of Digital Equipment Corp, 1977.
December 21st, 2004, 10:39 PM
It does not show up in hard drive section. It does not show up anywhere. |
December 21st, 2004, 10:40 PM
Did you try playing with the jumpper settings?? |
Are you sure all the connections are secure? Double check to make sure |
December 21st, 2004, 10:41 PM
| | Supporting our military
You need to tell us your exact setup so that we can help.
Bill
December 21st, 2004, 11:00 PM
I have a Promise PCI IDE card with 2 connectors I use one for my DVD Rom and it works fine. I am using the secind connector for the third HD, I have swithed both around and same result. /DVD works fine. The problem by be in the jumper. The chart they show is not ver clear. I will play with that and see.
Thank you so much for your prompt help. |
December 21st, 2004, 11:22 PM
| | Super F@D Folder
i think if you have a pci ide card it does not show up in the bios...but i could be wrong...don't have any experience there. sorry i can't help...but see if windows can find the drive..if windows can find the drive then you should be all set  |
December 22nd, 2004, 03:35 AM
What brand & model is the hard drive?
Let us help clarify the jumper settings issue. |
