Need Help removing trojan horses :(  | |
December 24th, 2004, 02:15 PM
hey i just signed up on this forum as i have tried everything i know about removing trojan horses and my comp is really messed up and running slow as well as nortons message popping up everythime saying i got a trojan horse. please could someone help me to remove these trojan horses thanks a lot
ZIM  |
December 24th, 2004, 02:18 PM
| | Banned
Do you know its name,do a search on the internet and you will see thousands of hits. |
December 24th, 2004, 02:42 PM
Norton may recognize the trojan but be unable to remove it. I agree that googling for an answer would be a good step. You also should download and install additional anti-malware programs. Ad-Aware SE and Spybot Search and Destroy, both of which have free versions, are good choices.
BTW Welcome to TechImo.
If you can't say something nice... SAY IT REALLY LOUD!!
Only two defining forces have ever offered to die for you,
Jesus Christ and the American G. I. One died for your soul; The other for your freedom
December 24th, 2004, 03:04 PM
| | Pump you sucker! Pump!
I used the free on line Panda... if found (and removed) stuff Norton missed: http://www.pandasoftware.com/activescan/
Run your AV scan (s) first, then run Adware everytime you close IE.
EDIT: Welcome to Techimo!
Obama has taken America from purported bully to notorious chump in less than a year.
December 24th, 2004, 05:41 PM
I would use Kaspersky anti-virus to get rid of it. I had one last week that AVG detected but could not remove it, Kaspersky took care of it. IMO this is the best anti-virus software out there. I'm cheap and I would still pay for it. http://www.kaspersky.com/ |
December 24th, 2004, 06:02 PM
hey well i just checked it out and there is no name popping uip all it says is nortons has found a trojan horse and it shows the affected file.
i hvae used spybot etc etc to clear all spyware but i need something that could possible remove this virus. is there any suggestions thanks for the welcome guys
ZIM |
December 24th, 2004, 06:04 PM
best bet to remove it is use the software every one here has listed and then boot into safe mode ( tap f8 while windows is loading). safe mode would give you a higher chance of removeing it permenently.
if it is not broken, play with it till it is.
December 24th, 2004, 06:58 PM
I'm surprised that Norton identifies a Trojan (viruses and trojans are different) but does not tell you the name of the trojan. What is the name of the file(s) that are infected? Finally it may be that if Norton is using a heuristic logic it may be identifying something that is perfectly fine but thinks it's actions resemble that of a trojan. If you have a registered version of Norton you may want to contact them for support.
Keep us informed. |
