Problem connecting Canon A75 to pc
Currently Active Users: 1619
Discussions: 200,509, Posts: 2,374,406, Members: 245,832
Old December 26th, 2004, 12:27 PM   Digg it!   #1 (permalink)
elroy's Avatar
As I posted earlier I purchased a Canon A75 digital camera for my wife for xmas. I thought this was a good idea. I need to set up the included USB cable to download pictures to the pc. Problem is it will only work if I disconnect all other USB devices from the pc, otherwise the camera is "not found". I've re-installed all software and twain drivers numerous times. Even installed it on a 2nd pc. Canon's website said to unhook other USB devices for the installation but once it is installed and working if I hook the printer, scanner and another media card reader back up the camera is once again "not found". I'm running Win2k on a 3200+ with 512mb of PC3700 ram and the USB ports are version 1.1
I don't want to be removing the memory card from the camera constantly as it will be used a lot and the little door wouldn't take the constant use. Anyone here been thru this? This thing is just about to go back to the store.
UPDATE: I have determined there is a conflict between my USB scanner and the camera. The camera is recognized and transfers pictures fine as long as the scanner is unhooked. At this point it would seem to be a Twain driver issue?
elroy is offline   Reply With Quote
Old December 26th, 2004, 02:20 PM     #2 (permalink)
I use an elcheapo digital camera, and two different Visioneer scanners. I use Paint Shop Pro to load any images into the machine. When I connect any of these devices, I must first open PSP, then click File > Import > Twain > then, select source/acquire...I usually have to select source first because (maybe) one of the scanners was last used.
Maybe this is not your problem...needing to select the source, but could be?...
Bovon is offline   Reply With Quote
Old December 26th, 2004, 09:48 PM     #3 (permalink)
jrsweger's Avatar
elroy, when this happens, do you see the problem on the Device Manager screen? I've seen this before with my Canon A70. I also believe it was a conflict with the USB scanner. In my case, my scanner was not fully supported in W2K and I picked up a driver from Visioneer that said use at your own risk. I ended up taking the scanner off the PC. Microsoft had a hotfix out that I tried, but it did not fix it. I'll look around to see if I can find the file and the directions if you'd like them.
jrsweger is offline   Reply With Quote
Best digital camera for under 200 bucks? rockpile General Tech Discussion 14 January 7th, 2009 08:36 PM
Digital Cameras super gerbil General Tech Discussion 8 December 17th, 2004 11:10 PM
need a new digatal camera pvt. blackburn Multimedia and Audio 3 October 16th, 2004 09:46 PM
Digital Camera Suggestions! brandon184 General Tech Discussion 29 June 26th, 2004 05:05 PM
Which printer is better? Yankees4 General Tech Discussion 10 May 27th, 2002 06:40 PM
Is It Just Me? (1635)
Review My Build (6)
Assosiations (21496)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
boot from CD-ROM in chipset via P4M80.. (0)
Review My Build (6)
windows 7 retail and rtm (1)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
