Results 1 to 15 of 15
    Oct 2004
    145
    cd drive problem
    Hi i have cd/rw drive and a dvd drive. When i first purchased my computer i would always put cd's in the cd/rw drive, eg. games or music cd's. Though one day it just wouldn't detect the cd, i didn't think much of it and just used the dvd drive instead. But now i would like to use the abilities of the cd/rw drive like creating my own music cd's. Is there anyway of fixing this problem or is the laser just bust in the drive? maybe the computer disabled the drive or something like that i don't know, but any help would be appreciated. thanks.
    Ultimas w00t! Mastah... vikeor's Avatar
    Warsaw, Poland
    6,443
    is the drive still recognized by the computer?
    AMD Opteron 146 2.8ghz 280x10
    1GB GEIL ONE S PC3200
    DFI LanParty UT NF4 Ultra-D
    ATI X1800XT @ 700/800
    Enermax Noisetaker 485W
    BigWater SE
    Oct 2004
    145
    yeh, it says the cd/rw drive is drive ( G: )
    Senior Member excuzzzeme's Avatar
    Jun 2003
    978
    Check to see if it was detected in BIOS.
    Check to see if Windows detected it in the device manager.
    If in Device manager, try to remove and then allow it to re-install.
    If #1 #2 are good and #3 not, I would suspect that it has died.
    First make sure all cables and power connectors are tight and in place properly.
    Only two defining forces have ever offered to die for you,
    Jesus Christ and the American G. I. One died for your soul; The other for your freedom
    Warsaw, Poland
    6,443
    if u put in a CD can u hear it spin?
    BigWater SE
    Oct 2004
    145
    i think its spinning the cd is facing a different angle from when i put it in and does make a little noise for about 2 seconds dosen't sound as healthy as when i put it in my dvd drive though.
    Warsaw, Poland
    6,443
    hmmm... bad sounds are not good :P might be a dead drive...
    BigWater SE
    Oct 2004
    145
    yeh i think it must just be broke, but thanks for the help anyway.
    Warsaw, Poland
    6,443
    no problem... get a better new one
    BigWater SE
    Oct 2004
    145
    hey sorry, just looking at cd/rw drives. Does it matter which one i go for? will any one fit in my comp.? cheers for any advice.
    Warsaw, Poland
    6,443
    yup, any drive will fit... go for a more known brand like Plextor or Sony if u dont want to have trouble. U might as well get a DVD burner now, they're pretty cheap.
    BigWater SE
    Oct 2004
    145
    can a dvd burner also burn normal music cd's?
    Warsaw, Poland
    6,443
    yup
    BigWater SE
    Oct 2004
    145
    ahh nice, didn't know that thanks vikeor you've been very helpful today.
  15. #15
    Warsaw, Poland
    6,443
    hey, no problem
    BigWater SE
  1. CD ROM refresh problem in XP Pro
    By gavman in forum Multimedia and Audio
    Last Post: May 28th, 2004, 10:11 AM
  2. HELP! CD-RW will read, but won't write!
    By ND4SPD in forum Technical Support
    Last Post: August 10th, 2003, 01:27 PM
  3. Copy CD's on CD/RW drive
    By dlh75 in forum Storage Related
    Last Post: March 1st, 2003, 02:52 AM
  4. Clicking Hard Drive
    By franklin jones in forum Storage Related
    Last Post: April 13th, 2002, 09:29 PM
  5. Scary noises and no boot
    By hhh8785 in forum Technical Support
    Last Post: January 18th, 2002, 01:10 PM
