USB problem
Currently Active Users: 2137
Discussions: 200,948, Posts: 2,379,397, Members: 246,309
Old January 12th, 2005, 05:30 PM   Digg it!   #1 (permalink)
USB problem
the onboard usb's for my mobo all of a sudden do not work anymore, i recently bought another mobo (the same one Asus P4P800 SE) because the first time i plugged in my mp3 player to the front usb port my mouse disappeared and my computer started acting funny so i restarted then it said my usb items weren't functioning. Then i had to goto work and when i came back my computer didn't even come on, so i posted here and they said my mobo was fried or my processor... So i ordered another P4P800 SE and a new processor and everything seemed fine until a couple of days later i plugged my mp3 player again in the front and my monitor shut off forcing me to restart, so i did and now the new mobo is doing the same thing except it's not acting funny , it acts normal just the usb's are not working. What could this be and should i just by a usb hub PCI card to fix this, or would it?
thanks...in advance.
nate
P43.2Ghz
80GB hd
512 pc 3200 (400mhz)
ATI AIW 9600 PRo
Asus P4P800 Se mobo
shynomi is offline   Reply With Quote
Old January 12th, 2005, 05:37 PM     #2 (permalink)
Send a message via AIM to Shabow
Why cant you just plug it into the back of the mobo?
Shabow is offline   Reply With Quote
Old January 12th, 2005, 05:44 PM     #3 (permalink)
Banned
pphalan's Avatar
You have to use the disk for your mobo or visit the website to download USB drivers, each mobo has its own drivers for USB ports
pphalan is offline   Reply With Quote
Old January 12th, 2005, 07:28 PM     #4 (permalink)
the usb's on the back aren't working as well as the front, So you think it's just the drivers, i hope it is, i have the disk which has the usb 2.0 drivers on it but i tried to install it and it says that windows xp will already install them. anyway i'll try them as soon as i get off of work. thanks if this doesn't work, would it be better just to get a pci usb 2.0 card? what about updating the bios? it's so weird they worked fine earlier...anyway thanks so far. nate
Old January 12th, 2005, 07:41 PM     #5 (permalink)
digby0668's Avatar
You might need to delete the old drivers to get windows to reinstall them. Goto device manager and delete them.
digby0668 is offline   Reply With Quote
Old January 12th, 2005, 07:53 PM     #6 (permalink)
Banned
pphalan's Avatar
After you delete use the mobo drivers not windows
Old January 12th, 2005, 11:19 PM     #7 (permalink)
i'll try that, i hope that works, i'll post back in a short bit. thanks.
Old January 13th, 2005, 12:09 AM     #8 (permalink)
one problem the mobo disc that has drivers on it only has drivers for 98se and 2k, it says that windows xp sp1 will find the drivers for it. is there a site i can get these drivers, i checked the asus.com site and it only had usb drivers for 2k. thanks.
Old January 13th, 2005, 02:58 PM     #9 (permalink)
phecky's Avatar
Are you sure you've got the wires from the case connected to the proper mobo header pins in the proper order? Just asking.
The World needs to change from revolutionary thinking to evolutionary.
Barton 2500+
1 gig corsair
ATI 9800 Pro
VIA kt600
phecky is offline   Reply With Quote
Old January 13th, 2005, 03:13 PM     #10 (permalink)
yes i even reconnected them, just to make sure.
Programs locking when I print colt Technical Support 4 May 29th, 2004 12:51 AM
Big Conflict!!! watzmann Technical Support 9 October 18th, 2003 04:01 PM
Wireless USB adapter $11AR John Prophet ResellerRatings Homepage Deals 2 September 16th, 2003 05:34 PM
Epson (im)Perfection 1250 PartsMan General Tech Discussion 9 July 9th, 2002 09:06 PM
USB Problem on M571 PC Chips MOBO CrashFlame Motherboards 4 February 2nd, 2002 10:45 AM
Making Health Care Worse (172)
The disrespect of Obama by Russian .. (22)
Is It Just Me? (2935)
Regular Build (6)
Print spooler problem (15)
Graphics Card Upgrade Question (3)
How to convert MP3's (3)
Internet Lost (1)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
