Thread: Bad Power Supply?????
January 23rd, 2005, 10:55 PM #1Member
- Jun 2004
- 72
I turned my computer off for two days straight (out of town), so when I get back in town, I try to turn it on and it acted like it wanted to then just turned off 2 sec after hitting the power button. Is that the power supply or motherboard?
Mat
January 23rd, 2005, 11:13 PM #2
Check to make sure your cards and ram are seated properly and that your cpu fan spins first. If the heatsink is seated well and everything else is normal then you'd have to guess the power supply is toast.
Just thinking that if your pc is usually on 24 hours and you turned it off and turned down the furnace to go out of town the temp difference could have shifted a card. My Audigy card would pop out alot like that.Last edited by rabidaardvark; January 23rd, 2005 at 11:18 PM.
size=1 rocks
January 23rd, 2005, 11:14 PM #3
hmmm
If you didn't add any hardware or anything, then it should not be the power supply. Unless its failing but i am not srue about that
Maybe the power button got stuck or anything like that. Check for thatSuper Gerbil
January 23rd, 2005, 11:20 PM #4Member
- Jun 2004
- 72
It will act like it will want to turn on, but nothing. Seems to me when it gets hot it shuts off. All the fans are turning until it shuts off.
Mat
January 24th, 2005, 12:09 AM #5
Well I'd clear bios, take everything out but the ram and video, reseat the cpu heatsink and if that fails start looking for a new psu.
size=1 rocks
January 28th, 2005, 02:29 AM #6
could be the PSU... i also have an experience working with an enermax psu. i turned it off in the morning before going to work, in the afternoon when i turned it ON, it blew up..literally, sparks and burnt smell...
Error when trying to install XP Pro on a new box
By Makaze in forum Applications and Operating SystemsReplies: 5Last Post: January 8th, 2005, 11:01 PM -
problem with harddrive
By bigfeta in forum Storage RelatedReplies: 25Last Post: June 25th, 2004, 12:00 AM -
Computer Randomly Restart
By stuwazhere in forum Technical SupportReplies: 30Last Post: June 24th, 2004, 01:40 AM -
Bad power supply?
By Pete1 in forum Technical SupportReplies: 2Last Post: May 6th, 2004, 09:30 PM -
HELP!! Rebooting constantly!!!
By GhostPoet in forum General Tech DiscussionReplies: 38Last Post: March 25th, 2004, 05:39 PM
Leonardo DiCaprio Wants Dennis Lehane To Pen Travis McGee Watch The Hangover Part 3 Online If you want some serious hints about what Season 2 will entail, this “Behind the Scenes Tease” is not...
