Results 1 to 10 of 10
Thread: Print Spooler
    Jan 2005
    5
    Exclamation Print Spooler
    Good Day to All,
    I seem to be having a problem with my Print Spooler. While installing my printer drivers that I recently downloaded from Lexmark, it stops me midway through installation saying I need to Start my Printer Spooler. I enter into Control Panel> Administrative Tools>Services, Double Click on Print Spooler and attempt to Start it and this is what I get:
    "Could not start the Print Spooler service on Local Computer.
    Error 1068: The dependancy service or group failed to start."
    This seems odd as my Remote Procedure Call (RPC) is running. When I look at windows task manager>processes, spoolsv.exe cannot be found.
    Any idea what I can do? Any help would be greatly appreciated. Thanks.
    Arizona_kay
    Senior Member TechKnickle's Avatar
    Aug 2004
    LA, California
    812
    What OS?
    People are like coins, there's always two sides.
    Jan 2005
    5
    Print spooler
    Im running Windows XP - Home edition
    Aug 2004
    LA, California
    812
    Have you tried anything like replacing the print spooler file with a known good one? Maybe it somehow got modified or corrupted? Although this does not seem the likely cause of this problem.
    Jan 2005
    5
    Print Spooler
    Any idea where i could find one?
    Aug 2004
    LA, California
    812
    Sure, I'll give ya a copy of mine. Win XP - Home SP2 spoolsv.exe
    http://techknickle.tripod.com/spoolsv.zip
    Jan 2005
    5
    Thanks..
    im gonna give it a try right now....ill get back to you whether it works or not
    arizona_kay
    Jan 2005
    5
    Print Spooler
    Looks like its a no-go. I replaced the file and the same error message came up. ANy other suggestions?
    Arizona_kay
    Ultimate Member [Neo770]'s Avatar
    Gold Coast,Australia
    2,477
    Also at a command prompt if you do a sfc /scannow from the command promts that will make window scan the system files for changes and replace any files that are not the right ones.
    Dec 2005
    4
    Question Print spooler turned off
    I have the same issue
    How did you resolve?
    Thanks for helping!
  1. Killing Print Jobs
    By Toddly in forum Applications and Operating Systems
    Last Post: November 17th, 2003, 10:47 PM
  2. Deleting print que?
    By Fingers in forum General Tech Discussion
    Last Post: March 6th, 2003, 12:05 PM
  3. Print Server Recommendations?
    By theodore in forum Networking and Internet
    Last Post: August 14th, 2002, 11:02 AM
  4. Windows keeps losing Printers!
    By Mead in forum Technical Support
    Last Post: February 7th, 2002, 10:21 PM
  5. 2k Bogged with 99% cpu usage
    By NeoStarO1 in forum Applications and Operating Systems
    Last Post: January 8th, 2002, 12:20 PM
