Page 1 of 2 1 2 LastLast
Results 1 to 20 of 22
    Member anhnguyen's Avatar
    Nov 2004
    95
    CPU running at 64C at boot?
    My water cooler says the temp is 24 while the BIOS gives 64. Is it possible for the CPU to run at 64?
    The water cooler sensor is placed rite next to the CPU so I'm really confused. I need some serious help rite now.
    Thanks.
    Nov 2004
    95
    Anybody?
    Nothing To See Here butch81385's Avatar
    Jul 2003
    PA
    15,092
    i would definitely check the connection from the cpu to the water cooler. 64 is quite high (though not necessarily automatically going to fry your cpu).
    Senior Member saladbarkid's Avatar
    Apr 2002
    TechIMO
    544
    It's possible one of the sensors could be acting up or not in the correct area under the cpu.
    20" iMac 2.16GHz / 1GB RAM / 250GB HDD / 8x DVDRW / OS 10.5
    1010011010 jmichna's Avatar
    Chicagoland IL
    3,249
    Air bubble trapped in CPU's heat sink?
    I am a banana! originel's Avatar
    Jun 2002
    Texas Tech
    3,921
    what cpu and motherboard? I've got an MSI K8N neo and while it's a great motherboard, i did have to update the bios to get it to report cpu temps properly
    Nov 2004
    95
    Its a Prescott P4 3.2 and GIGABYTE "GA-8I915P Duo Pro
    What? SoloCamo's Avatar
    Nov 2004
    Burning in Florida
    15,195
    4
    prescott is all you had to say ;p they run extremely hot compared to most processors
    Nov 2004
    95
    but 64, but sometimes 80 at start up? I don't think so
    Nov 2004
    Burning in Florida
    15,195
    4
    ya 80 is really really really pushing it, thats on the verge of destruction for the cpu, i would download all the latest bios drivers because thats most likely your problem especially since the water cooler is reading 24
    Chicagoland IL
    3,249
    2nd time: check for air bubbles in your watercooling system, especially in the heatsink platen.
    Nov 2004
    95
    I did try that. The water flows fine. Is there a chance that the BIOS sensor is mistaken? Because when I touch the water block on the CPU it feels cold, not even warm. And how do I update the BIOS to make sure that the temp is right?
    Aug 2003
    Gateshead U.K.
    11,328
    have you even got the water block installed correctly?
    Nov 2004
    95
    Ok. I am really freaking out now. I just reposition the CPU block so its facing the opposite position and now the water cooler displays 78... The water still flows. Oh man I am so mad!!
  15. #15
    Ultimate Member jml90's Avatar
    Feb 2004
    Folsom Prison
    1,308
    Well apparently thats not right so just thake the temeperature inside the case the bios temp. is prbably just messed up.
    When you're runnin' down my country, man
    You're walkin' on the fightin' side of me
  16. #16
    Ultimas w00t! Mastah... vikeor's Avatar
    Warsaw, Poland
    6,443
    try and update the BIOS... i have a gigabyte mobo and i had false readings b4 i updates the bios.
    AMD Opteron 146 2.8ghz 280x10
    1GB GEIL ONE S PC3200
    DFI LanParty UT NF4 Ultra-D
    ATI X1800XT @ 700/800
    Enermax Noisetaker 485W
    BigWater SE
  17. #17
    Nov 2004
    95
    Uh.. how do you update the BIOS? Sorry guys I am a beginner so I don't know much...
  18. #18
    Aug 2003
    Gateshead U.K.
    11,328
    try with the original air cooling back in place so you have a reference point.
  19. #19
    Warsaw, Poland
    6,443
    BIOS file: http://tw.giga-byte.com/Motherboard/...0Duo%20Pro.htm
    then u have to dload the Flash Utility off the gigabyte website too... Its pretty self-explanatory from then.
    BigWater SE
  20. #20
    Warsaw, Poland
    6,443
    heres a nice step by step guide for u
    http://tw.giga-byte.com/motherboard/...oreflash_1.htm
    get @BIOS really easy to use.
    BigWater SE
  1. What is normal CPU Temprature?
    By muarrif in forum Processors, Memory, and Overclocking
    Last Post: October 5th, 2004, 04:00 PM
  2. Weird BF1942 lag
    By ShawnD1 in forum General Gaming Discussion
    Last Post: May 3rd, 2004, 07:25 PM
  3. Upgraded CPU, now PC will not boot
    By TyrantCS in forum Technical Support
    Last Post: April 10th, 2004, 03:15 AM
  4. Self-contained CPU water cooler?
    By rourkchris in forum Processors, Memory, and Overclocking
    Last Post: March 24th, 2003, 10:35 PM
