my computer wont start....please help  | | |
February 9th, 2005, 12:18 AM
my DAW/DVW wont start....advice plz
it just, shut off! black screen, deafening silence......
and now it wont restart...
symptoms:
1) turned off unexpectedly while running a few programs (discreet combustion, ms mediaplayer, norton IS, all were running at the time, but I doubt this is a software issue)
2) motherboard light is "ON"
3) put in new powersupply, no help
system-->
1) asus p4-533-c mothrbrd, w/ new 3.06ghz p4 chip (and newly flashed bios chip)
2) new 400watt power supply
3) 1 gig ram, new
4) emu 1820m, new
so tell me, WHAT could be wrong---the actual power switch itself??
February 9th, 2005, 12:25 AM
| | ph34r t3h g04t
Sounds like you burned something. Try removing everything and then reinstalling piece by piece. Start with just the CPU, RAM, and video. Or if you have on-boad video at all, try that first before installing the AGP/PCI card. |
February 9th, 2005, 12:30 AM
I have had the same problem when I tryed to overclock my PC. Was working then  boom  shut off. I reseted ther CMOS switch on the motherboard and then it came back to normal. |
February 9th, 2005, 12:48 AM
| | ph34r t3h g04t
Hah, that's a good idea. I think too far ahead.  |
February 9th, 2005, 12:51 AM
| | Rock of Ages
| Quote: |
Originally Posted by synthetic0420 (and newly flashed bios chip) | Question is... did you flash it.. forget about it for a while and restart... and this is where your @?
try what whir had said... remove everything execpt the essentials . reseat video,memory , & the proc.
PULL the cmos battery for 10 minutes @ least.. try again after you place it back in... if it dont work, take your chip and memory to a local shop to have them test... my guess is you burned the board out... maybe the proc took one as well on ya...
__________________ Waitin' for the THWACK! |
February 9th, 2005, 04:31 PM
JOKOSTEL & BIYA
I should clarify that nothing AT ALL happens when I push the power switch, it doesnt even get to system beeps or anything, thats why I think the switch may be bad, Im having an electrician look at it tonite
no,
actually asus flashed the bios chip for me (1010c), and things have been running smoothly for over a week....I let the comp sit over night, and even replaced the powersupply before I ever posted on this forum...
I will try resetting cmos /] battery (fingers crossed), I have tested ALL other ram, cards, processor etc they all work in my other comp--
btw, what do you mean by "maybe the proc took one as well "---does proc= processor? no, it is in working order as well
THANKYOU guys, btw!!! |
February 9th, 2005, 05:06 PM
| | Super F@D Folder
sounds like the mobo..or maybe the switch..the way to tell is to take a paperclip and a larger eraser... make the paperclip into a u and stick it through the eraser and then look what 2 pins the power switch connects to on the mobo and take the connector off..then touch the 2 pins w/ the ends of the paperclip....lol..i don't usually use the eraser..but that's probably the best way to do it....more to keep u from shocking the system then from the system shocking u...but i'd bet it's the mobo! |
February 9th, 2005, 08:32 PM
mobo......hmmmm, I will look into this, thankyou
possibly the side circuit, or does that come out of the mobo?
cmos resetting and battery have not worked |
February 10th, 2005, 12:29 AM
I have replaced the power switch (reset solders as well), checked/tested/ replaced CPU, reset cmos & battery, run jumper/jumper free mode.....nothing.....nerd kru is stumped
board tests fine.......my only other theory is the on/off side circuit that controls stratup power has gone bad?
(yes I work grounded)
February 10th, 2005, 12:48 AM
you tryed your components piece by piece in a diffrent pc to validate whats working right and whats not ? |
