Results 1 to 5 of 5
    Senior Member Dooin' it's Avatar
    Aug 2003
    657
    To FLASH or WinFlash or NOT to flash at all??????
    Well, here's my dilema. Built a nice little system for a guy & used a Sempron 2200 in an ECS K7VTA3 (6.0) board.
    But.........(right)........
    Sempron shows up as an Athlon 1500. (Because it's running at 1.5Ghz like it should on 333fsb).
    I'd *like* to make it show "Sempron 2200+" in the bios, but it looks like I can only use Winflash & I'm not familiar & not necessarily comfortable using that utility after some of the horror stories I've Googled.
    Sure, I'd feel comfortable doing the DOS bootdisk & upgrading with DOS utility, but it looks like the file is only available in Winflash format.......Grrrr!
    Should I even bother?????
    Linkage to files at ECS ----------> http://www.ecsusa.com/downloads/down...to=Motherboard (You have to jump java scripts to get to the K7VTA3 (6.0) downloads & go to BIOS)
    Ultimate Member blubomber's Avatar
    Reno, NV
    1,624
    Do the update. Second i found this on the ECS website.
    It had the BIOS file and the flash utility using the DOS boot disk method. I personaly have not see a motherboard manufacturer make you use the winflash utility. The MB manufacturer should always supply the BIOS program and you can go to the manufacturer of your BIOS chip to get the flash utility if you have to, Award and the other one.
    Hope fully that link will take you to the right place. Good Luck!
    PS. I dont like the winflash utility either.
    "Life moves pretty fast, if you dont stop to look around once in a while, you could miss it." -FB
    Super F@D Folder
    Jun 2004
    5,091
    well..i've used winflash once and it worked like a charm...no problems at all. it made me nervous but as it was a work computer...oh well lol. it worked fine though
    Aug 2003
    657
    blu,
    Cool.......thanks, but I do need your help still..........
    Your link did the same thing mine does.............leads to java pages.....he he.
    Can you describe how you got to where you found the DOS file for the update & utility??????
    Thanks again!!!
    Aug 2003
    657
    OK..................I bit the bullet!!!!!
    I just winflashed it & all went well. I backed up the old bios first & saved it just in case, but it went fine. I didn't know what to check, so I just checked "update all" since I'm no pro on the blocks within the bios.
    Only scare I had was when it said, "load binary file again?" and I freaked for a second & cancelled. Then I re-read the "how to use Winflash" and could barely see.......(the pdf file for the tutorial sucks).......that it *does* actually show this and you simply click "yes" again, then click "update" & watch it go.......
    .........w/ your butt cheeks pinched together tightly so as to help the process along........LMAO!!!!!!!!
  1. Need help on Winflash...
    By Chuckiechan in forum General Tech Discussion
    Last Post: July 27th, 2004, 11:18 AM
  2. Need Some FLASH Help!!!
    By omc1jz in forum Graphic Design and Digital Photography
    Last Post: June 13th, 2003, 09:28 AM
  3. flash help!
    By puk in forum Webmastering and Programming
    Last Post: May 16th, 2003, 01:37 PM
  4. Flash MX help!
    By Creatures in forum Graphic Design and Digital Photography
    Last Post: February 7th, 2003, 01:41 PM
  5. Flash non-user wants to get past Flash only intros
    By dunbar in forum Graphic Design and Digital Photography
    Last Post: February 4th, 2003, 02:11 PM
