Results 1 to 5 of 5
    Ultimate Member Vagabond's Avatar
    1,757
    Excell and hyperlinks
    I would like to change the excel default hyperlink browser from IE to Avant where can i do this. I look thought the options and some of the pull down menus but either missed it or did not look in the right places..
    Win XP
    Excel 2002 sp3
    txs
    You know dog spelled backwards is god.....
    coincidence ..... i think not.
    Member jpiermarini's Avatar
    Mar 2005
    Massachusetts
    428
    you need to make avant your default web browser and not IE. Fire Fox is my default web browser and when i have a hyperlink in excel it opens it in firefox and not ie. so make those changes and you should be all set
    Ultimate Member Smidley's Avatar
    Mar 2004
    USA
    1,525
    Yup.
    1,757
    ok i am missing something.
    at step 2. it says "On the taskbar, click Start, and then click Set Program Access and Defaults"
    this is the little start button on the bottom left but i dont see a Set Program Access option. I have service Pack 1. Where do i need to go? txs
    i want to change the default from IE to Avant.
    txs
    Mar 2005
    Massachusetts
    428
    there will be two locations where you can find Set Program Access, the first is on the start panel. if its not there open the control panel and then go into Add or Remove Program and the option is on the left hand side on the bottom. i included two screen shots for help.
    Attached Thumbnails Attached Thumbnails Excell and hyperlinks-control.jpg   Excell and hyperlinks-start.jpg
  1. Hyperlinks
    By truckpuller in forum Suggestion Box
    Last Post: July 20th, 2004, 11:15 PM
  2. Entering hyperlinks
    By osprey4 in forum Suggestion Box
    Last Post: May 8th, 2004, 10:11 PM
  3. Hyperlinks not open in OE
    By tboy in forum Technical Support
    Last Post: December 20th, 2003, 02:58 PM
  4. searching for hyperlinks?
    By stevece in forum Applications and Operating Systems
    Last Post: April 21st, 2002, 09:08 PM
  5. Hyperlinks in emails
    By GiganticDays in forum Applications and Operating Systems
    Last Post: March 2nd, 2002, 11:25 AM
