Page 1 of 2 1 2 LastLast
Results 1 to 20 of 30
    Senior Member lablkilz699's Avatar
    SF Bay Area
    953
    Limewire Barely Works
    Hi, my limewire has basically stopped working. I dono whats wrong with it but whenever i try to use it, it opens up, but is basically frozen or extremely slow. Half the time no text even shows up just gray. I tried re installing it but that didnt work...i dono what to do, any help... thanks
    The Macedonian Member njolakoski's Avatar
    Mar 2004
    On my GSXR 1000
    3,370
    No problem here it works perfectly
    SF Bay Area
    953
    thanks for the advice, lol
    Mar 2004
    On my GSXR 1000
    3,370
    Maybe if you re-download Limewire?
    SF Bay Area
    953
    read orginal post....said i already re installed it.
    Newbie filipino's Avatar
    May 2004
    Philippines
    3,922
    firewall maybe?
    I miss Dimebag Darrell
    Mar 2004
    On my GSXR 1000
    3,370
    Quote Originally Posted by lablkilz699
    No Not reinstalled it, re download it then reinstall, it Im just making a suggestion, but What Filipino said you should check into, maybe your Firewall is turned on?
    Jan 2003
    MA / NH
    1,497
    What version are you running?
    -Blaze
    SF Bay Area
    953
    well, i make a point to turn off windows firewall, then yes...i redownloaded, and reinstalled is what i meant...still not working.... and Limewire 4.8.1
    Ultimate Member rastorize's Avatar
    Jul 2002
    sacramento
    1,165
    When you reinstall - are you just installing over the original installation? Or, did you completely delete the installation folder and start fresh? Do you have any unfinished downloads that are waiting to be finished? Maybe that's causing the slowdown - a corrupt file or virus?
    SF Bay Area
    953
    i had a feeling in the back of my head that its a corrupt file or virus for some reason....
    SF Bay Area
    953
    i would uninstall the folder but its not there so i dono what to do
    Jan 2003
    MA / NH
    1,497
    In the same folder that your P2P folder is stored, there is another called INCOMPLETE... delete the contents of that. (also, you will loose any download you had going at the time)
    -Blaze
    Ultimate Member survivalhero's Avatar
    Apr 2004
    cali
    1,223
    I've had the same problem. How much ram do you have? limewire eats so much ram it's insane can't really multi task with it unless lots of ram of course but yeah mine use to be really really really slow and it pissed me off cause welll limewire is good. Anyway yeah got another stick of 512 and limewire pro fixed the problem... hope that helps and if you have a gig of ram then I have no idea
    Jambalaya
  15. #15
    SF Bay Area
    953
    yeah...definitely not ram....it was working extremely well until like yesterday when it randomly started basically freezing up.
  16. #16
    Apr 2004
    cali
    1,223
    Hmmm, then I have no idea... sorry
    Jambalaya
  17. #17
    Member Messiah89's Avatar
    Jan 2004
    Jupiter, Florida
    358
    I have this same problem with LimeWire, it is extremely slow and lags my system.
    My 700MB of free memory turns into about 40MB free when I open LimeWire, and the CPU usage is close to 100%.
    This happened even before I reformatted Windows when I upgraded to my A64.
    I've tried everything and it won't stop.
    AMD Athlon 64 3000+ @ 2GHz
    Gigabyte GA-K8NSC-939
    Corsair 1GB PC3200 DDR RAM
    Maxtor 120GB 7200RPM Hard Drive
    XFX GeForce 6600GT 128MB AGP
  18. #18
    Mar 2005
    England
    1,083
    Limewire started going really slow on mine too. I personaly felt it was something to do with the java that it uses & makes it quite demanding.
    I just use a couple of other more responsive p2ps now. Maybe you should look elsewhere for a less lagging app.
  19. #19
    Apr 2004
    cali
    1,223
    I think that it's because it's just limewire regular. Pro runs alot better and I understand that you guys probably don't want to spend the 40 bucks or w/e it was I paid but it runs lots better.
    Jambalaya
  20. #20
    SF Bay Area
    953
    i jsut got bear share. and yes, i scanned my computer and it said there was a virus it coudnt remove, somthing with the word Java in it so im assuming thats all connected...?
  1. Limewire
    By nwo75200 in forum Technical Support
    Last Post: January 16th, 2008, 10:50 PM
  2. limewire problem
    By izaic3 in forum Technical Support
    Last Post: April 25th, 2004, 01:31 AM
  3. Mandrake 9.0 and Limewire
    By jkrohn in forum Applications and Operating Systems
    Last Post: January 20th, 2003, 02:35 AM
  4. Limewire 2.0 = virus?
    By Pshawn5 in forum General Tech Discussion
    Last Post: December 29th, 2001, 05:15 PM
